Local Time 12:23 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : The latest MMBasic and more..- Help !
Tim036
Posted: 03:57am 21 May 2015
To get the full benefit of MMBasic 4.6B (hope that is what its called) is the
PIC32MX170F256B 28 pin PIC the best choice ? Does any other PIC (e.g. the 44 pin version ) offer any extra speed or RAM size ?
Is there a way of telling which version of Basic is on the PIC once you are accessing it ?
I've got loads of questions, such as is there a neat way of downloading or uploading programs into it and out of it ?
I use Linux Ubuntu 14.04 so I've found from the linux 'terminal' this works a treat:-
picocom /dev/ttyUSB0 -b 38400 -l (lower case L)
Any thought very welcome !
Tim
DaveC166
Posted: 11:02am 21 May 2015
Hi TIM036,
Both the 28 pin and 44 pin versions of the MX170F256 running MMbasic ver 4.6B, have the same RAM and clock speeds. The only difference is the number of I/O pis available. The 28 pin MX170, being a DIP package offers 19 I/O pins and is Breadboard or vero board friendly. The 44 pin version has 33 I/O pins in a TQFP SMD format.
At the command prompt Type PRINT MM.VER (enter) this will tell you the MM basic version.
Check out the manual for XMODEM send/recieve and EDIT comands for retrieving/loading/editing Umite programs
palcal
Posted: 11:11am 21 May 2015
Have you downloaded the manual from Geoff's web site, most questions will be answered there. To find the current version of software use the command MM.VER. As far as I know the 44 pinner only offers more I/O pins. Downloading and uploading can easily be done using MM EDIT available from the web site.
Paul.
Edit. There is a beta of the PIC32MX470 available that has more memory and speed.Edited by palcal 2015-05-22
Tim036
Posted: 11:27am 21 May 2015
Many many thanks for the replies ! They answered my questions and I feel know I've got lots of sources of information that I didn't have before !
Brilliant !!!
a very happy,
Tim
Tim036
Posted: 11:06am 23 May 2015
Saving a mmbasic programs to my Laptop. Also to be able to load them into MicroMite from the laptop.
I use Ubuntu 14.04 Linux, so Windows solutions are not what I need. (not keen to change OS).
Best I've found so far is:-
Quote:-
Xmodem
the best way to pass a file through xmodem is to use 'sx'. In debian this application is part of 'lrzsz' package.
In debian:
apt-get install screen lrzsz
screen /dev/ttyUSB0 115200
Then press Ctrl-A followed by : and type:
exec !! sx yourbinary.bin
This will send the file to ttyUSB0 over xmodem protocol
end quote
For 'Edit' in the mmbasic manual, all I found was on page 45 and 46 and that was it.
______
I guess I'm having a typical 'Newbie' panic attack, on this detail of being able to save and reload software into MMBasic.
Is there an Idiots guide how to do it ?
(I'm note sure if there is such a thing as a VT100 emulator in Linux available software archives)
Practically every serious user must stumble into the same problem ? I feel a bit of a dumbo that I've not yet spotted it !
Any thoughts very welcome !
A puzzled,
Tim
