Local Time 12:22 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PCB track width calculator...
Posted: 02:26am 18 May 2015
Hi folks.
While looking around the net, I found this neat web-based PCB track width calculator:
Track Width Calculator
What's neat about it, is that it is very flexible and allows easy calculation of track widths depending on current, distance, trace length and pour thickness. Many different units including inches, mm, mil etc. Calculated both internal and external track widths.
I like this page!
Posted: 03:01am 18 May 2015
I think you are now a fully qualified 'PCBoholic'
(good find though!!)
Posted: 02:33pm 18 May 2015
I needed to be able to pass about 3-amps through some tracks, so wanted to make sure I was making them big enough. I was using the "1mm per amp" rule, so the tracks were 3mm wide, which seems to be plenty according to the calculator.
