Local Time 12:22 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 12V Security PIR sensors
yobortsa
Posted: 07:39pm 13 May 2015
Hi folks,
Does anybody have any suggestions on how to interface 12V PIR sensors to a *mite? Should they be fed to the base of a transistor that shorts a digital pin to ground perhaps?
Further, can you retain the added security of having a series resister for each chain of PIRs to detect tamper? Would that require analog input?
Thanks in advance,
David
Posted: 07:58pm 13 May 2015
Hi David,
I have a PCB called MuP-Security that is designed for this (plugs into my MuP), however I still havent got any working code available to drive it.
But you may find a read of the manual might help you interfacing them...
MuP-Security
MuP Information is available here:
MuP
Other boards I offer can be found from the link in my signature below.
