Local Time 12:21 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMLib Enigma M4 emulation
shoebuckle
Posted: 04:29pm 30 Apr 2015
For those who are interested in the German Enigma cipher machine, Ray Alger has supplied a neat emulation of the machine and it has been added to MMLib.
Other additions to MMLIB since the start of 2014:
ASTROFIX Helps you track an astronomical body using an EM408 GPS module and Maximite.
BATTERY3 An updated version of Battery2 with option to save the final graph to BMP file.
CRUNCH Major change to format of source keyword files to make it easier to update.
Printer2 Printer subroutine for dot-matrix parallel-port printers
ClearBit to Bin8.bas function/subroutine library
Towers Towers of Hanoi game for MiniMite with VT100 terminal
Printer Method of printing from Maximite to dot matrix printer
Autolog Automatic daily logfile creation - builds a new filename for each day
GETIN Subroutine to get input with a timeout period - useful for menu system.
RTC-DOW Displays the name of the day of the week based on the MM RTC.
DCF77Clk A clock using the DCF77 radio signal
MMlLib can be downloaded from Geoff's web site at http://geoffg.net/maximite.html#Downloads
Have fun,
Hugh
shoebuckle
Posted: 08:24pm 17 May 2015
Ray Alger has created a version of Enigma for DOS MMBasic and this has been added to MMLib along with a program to generate setups for the device based upon a Seed which resets the MMBasic random number generator.
Both the DOS version (EnigmaD) and the original MaxiMite version (Enigma) now write the coded/decoded output to a file.
See Enigma.pdf in the library (dated 15 May 2015) for more detail.
Cheers,
Hugh
