Local Time 11:46 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Color Maximite Calls
Questarian
Posted: 07:28am 26 Apr 2015
Hi!
I'm fairly new to the color maximite and mmbasic (4.5), and I might have missed something in the manuals, but it seems mmbasic is a bit temperamental about entirely passing the results of complex expressions in command, function and sub arguments. For example something like:
seek #1,(fn-1)*fontv*fonth+1+i*fonth
fails
fi=(fn-1)*fontv*fonth+1+i*fonth
seek #1, fi
works
with user defined subs/functions, on a sub define as Sub Menu(x,y):
Menu Int((hres-menuh)/2+offseth),Int((vres-menuv)/2+offsetv)
works
menu (hres-menuh)\2+offseth,(vres-menuv)\2+offsetv
fails
what was driving me nuts, it that it's not all the time, or with every commands/functions/sub. I've used a lot of complex expressions with line, pixel and for commands without any notable issues, and in smaller test programs the complex arguments appeared to work fine, but once it get to a certain size. and/or nested in routines, things seem to start getting particular... any thoughts?
-John E. Bielak-Edited by Questarian 2015-04-27
twofingers
Posted: 07:53am 26 Apr 2015
Hi and welcome!
  Quote  what was driving me nuts
me too! But if you always use brackets
Menu(x,y)
or
Menu((hres-menuh)\2+offseth,(vres-menuv)\2+offsetv)
then it should work fine!
Michael
hitsware
Posted: 01:30pm 26 Apr 2015
> always use brackets
YES !!!!
Not only with Basic. Keeps things tidy ..........
Posted: 12:10am 27 Apr 2015
Welcome, Questarian. Love your avatar!
Posted: 12:19am 27 Apr 2015
MMBasic does have some problems with processing the argument list to subroutines and functions. Especially when you have a function call in the argument list.
The Micromite version has fixed this but I have not retrofitted the changes to the Maximite version yet (too many things to do).
The workaround is to evaluate any arguments that might cause trouble to variables before calling the sub/fun and then just use the variables in the call.
twofingers
Posted: 12:31am 27 Apr 2015
@Geoff
BTW. >argument list
Micromites have some problems with spaces between function call and the first bracket.
Menu(x,y)
works
Menu (x,y)
works not.
That's no problem if you know it but not easy to find if you not expect it.
Michael
Posted: 02:46am 27 Apr 2015
An amazing amount of MMBasic is dedicated to catching errors and trying to give a useful error message. But there seems to be any number of fresh ways to trip up the interpreter.
I will look at this one and see if I can catch it.
twofingers
Posted: 03:24am 27 Apr 2015
  Geoffg said  ... But there seems to be any number of fresh ways to trip up the interpreter.
my 2c:
Not worth the hassle when it comes at the expense of performance.
Michael
Questarian
Posted: 06:57am 04 May 2015
  Grogster said   Welcome, Questarian. Love your avatar!
Thanks! is part of my Theme...
Questarian
Posted: 07:11am 04 May 2015
  Geoffg said   MMBasic does have some problems with processing the argument list to subroutines and functions. Especially when you have a function call in the argument list.
That pretty much what i've been doing, breaking out the argument expressions to variables. it also helps breaking up long lines in smaller more manageable ones... It doesn't seem to affect every sub/function call so I've break them up when things start miss behaving.
-John-
