Local Time 11:06 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Basic Exponentiation
Posted: 08:49pm 24 Apr 2015
I just came across an interesting discussion on the PureBasic forum.
Do you treat 4^3^2 as
(4^3)^2 (left to right) or
4^(3^2) (right to left).
PRINT "4^3^2 = ";4^3^2
PRINT "(4^3)^2 = ";(4^3)^2
PRINT "4^(3^2) = ";4^(3^2)
Microsoft seems to work left to right and as MM Basic is based on GW Basic, it also uses left to right. This is stated in the manual so there should be no confusion.
It appears that many programming languages work right to left for 'power'
Mathematica 4^3^2 -> 262144
Maple 4^3^2 -> Error, power is non-associative
Maxima 4^3^2 -> 262144
Axiom 4^3^2 -> 262144
Reduce 4^3^2 -> 4096
Wolfram Language 4^3^2 -> 262144
Microsoft Visual Basic 6 4^3^2 -> 4096
MS Excel 4^3^2 -> 4096
perl 5 4^3^2 -> 262144 ie 4**(3**2)
Wikipedia says the exponential operator is right associative
http://en.wikipedia.org/wiki/Operator_associativity
In order to reflect normal usage, addition, subtraction, multiplication, and division operators are usually left-associative while an exponentiation operator (if present) is right-associative. Any assignment operators are also typically right-associative. To prevent cases where operands would be associated with two operators, or no operator at all, operators with the same precedence must have the same associativity.
Something to watch out for when translating programs and a good reason for lots of brackets.
Posted: 10:10pm 24 Apr 2015
Interesting.... though I don't think I've ever written a double exponentiation in any language!
Dylan
Posted: 09:09am 25 Apr 2015
There are two reasons to.
1) Computer Science 2^(2^5) = 2^32 = maximum memory for a 32-bit OS, for example.
2) Physical sciences (2^t)^(1/3) = volume of something doubling every t time units.
Just don't look up http://en.wikipedia.org/wiki/Tetration and all will be well.
BobD
Posted: 09:54am 25 Apr 2015
You mentioned it, I couldn't resist, I read the lot, and I am now more deranged than ever.
Posted: 03:19am 26 Apr 2015
  Dylan said   There are two reasons to.
For sure I've quite often used 2^32 one way or another, just never written it using a (to me pointless) double exponentiation.
