Local Time 11:06 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite : CFuncGen4PIC32 : V1.0.28
G8JCF
Posted: 12:27pm 13 Apr 2015
Hi
I have just posted the latest release of CFuncGen4PIC32 at http://www.g8jcf.dyndns.org/mmbasicmkii/
The main changes/fixes in V 1.0.28 are :
1) Added NoTabs check box - check if you do NOT want any tab characters in the CFunction source output - useful when pasting Cfunction source code directly into MMBasic's in-built VT100 text editor
2) Removed need to specify the development tool, ie no longer dependent on MPLab or MPLabX
3) Found and eliminated the defects which prevented Clean and Build in MPLab from working properly - CFuncGen was keeping directories opened needlessly, now, it just accesses the file(s) in the directory and then leaves the directory immediately afterwards.
4) Tidied up the formatted CFunction source output
You will need to uninstall the existing version of CFuncGen before installing CFuncGen4PIC32 - The old version is still available for download at the same site in case you want/need to revert to the original version.
I would be very interested to hear feedback from any CFunction authors regarding this new version - or indeed about anything else of course :)
Many thanks
Peter
The only Konstant is Change
twofingers
Posted: 12:57pm 13 Apr 2015
Hi Peter,
highly appreciated! Seems I have to begin to write CFunctions.
Thanks a lot!
Michael
G8JCF
Posted: 01:01pm 13 Apr 2015
Hi Michael
I thought it was you who first reported the problem with pasting into MmBasic VT100 editor with leading tabs
I always use MMEdit, so I never had that problem, but it was so easy to do, I added in NoTabs option
Looking forward to seeing your first CFunctions
Peter
twofingers
Posted: 01:35pm 13 Apr 2015
  Quote  I thought it was you who first reported ...
This must be a mix up! Sorry, I can't remember.
  Quote  Looking forward to seeing your first CFunctions
Hope this will happen soon!
Michael
G8JCF
Posted: 02:31pm 13 Apr 2015
Ah, it may have been @plasma in that case
Apologies for the mix up
Peter
