Forum Index : Microcontroller and PC projects : something a little cool
just happened on this link earlier on: "Ben Heck Creates A Pocket Computer Using A Xbox Chatpad and..." http://www.geeky-gadgets.com/ben-heck-creates-a-pocket-computer-using-a-xbox-chatpad-and-ardiuno-uno-video-11-09-2012/ the video clip is well worth watching. substituting a micromite instead of an arduino, seems like one could create a pretty neat pocket computer. does anyone know how small a screen the micromite editor can work with, ie, when setting OPTION DISPLAY lines [,columns] how few lines and columns will allow the editor to still function? cheers, rob :-) |
| kiiid Guru Joined: 11/05/2013 Location: United KingdomPosts: 671 |
This is cool! Just wait a couple of months and you might be able to see my mm laptop ;) http://rittle.org -------------- |
That was a video from 2012!. :) You guys are getting slow.:) Microblocks. Build with logic. |
| plasma Guru Joined: 08/04/2012 Location: GermanyPosts: 437 |
Watch out ! These cheap china clones have no pic inside ! Even you need the old chatpad from M$. the new ones are not working with the software. Imho the best way is to use a china clone(cheap) and Use a second chip which translate the datas to serial. |
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1162 |
Hi, it seems that the new chatpads have the same PCB as the old ones. It should be maybe possible to replace the chip with a PIC. It exists a driver for these chatpads (without changes) for Raspberry Pi. It would be nice to have a Raspberry with MMBasic and this small little keyboard. Is it maybe possible to implement this code into MMBasic for using this keyboard on a Micro-/Maximite??? Frank @Rob: Thanks for the Link - I buyed a chatpad and will try the Raspberry driver in the next days... |
