Local Time 10:25 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DS1307 on a Micromite issues with seconds
easterly81
Posted: 11:13pm 08 Apr 2015
here is the code I have been testing, but i cannot get the seconds to work.
I guess I don't understand how the RTCbuff(0) array is functioning.
Why does it not go:
sec------ RTCbuff(0)
min------ RTCbuff(1)
hour----- RTCbuff(2)
day------ RTCbuff(3)
date----- RTCbuff(4)
month---- RTCbuff(5)
year----- RTCbuff(6)
control-- RTCbuff(7)
i have messed with the order and strange thing happen. I could just be far off base, but if anyone can point me in the right direction it would be much appreciated.
ReadTime:
' I2C RTC based On DS1307 Secs,Mins,Hours,Day,Date,Month,Year,Control
Dim RTCbuff(8)
i2caddr = &h68 ' DS1307 I2C address
I2C open 100,100 ' Enable I2C
I2C write i2caddr, 0, 1, &h0
I2C Read i2caddr, 0, 8, RTCbuff(0)
I2C Close
sec$ = Str$(decimal)
BCDTEMP = RTCBuff(1)
BCDtoDec BCDTEMP
min$ = Str$(decimal)
BCDTEMP = RTCBuff(2)
BCDtoDec BCDTEMP
hours$ = Str$(decimal)
BCDTEMP = RTCBuff(4)
BCDtoDec BCDTEMP
day$ = Str$(decimal)
BCDTEMP = RTCBuff(5)
BCDtoDec BCDTEMP
month$ = Str$(decimal)
bcdtemp = rtcbuff(6)
BCDtoDec BCDTEMP
year$ = Str$(decimal + 2000 )
t$ = hours$+":"+min$+":"+sec$
D$ = day$+"/"+month$+"/"+year$
Time$ = T$
Date$ = D$
print t$, " ", d$
'Convert to Decimal
Sub BCDtoDec (BCDTEMP)
Decimal = Fix(BCDTemp / 16) * 10
Decimal = Decimal + (BCDTEMP And &hF)
Edited by easterly81 2015-04-10
BobD
Posted: 11:27pm 08 Apr 2015
You read your data into RTCBuff(0) and incrementing. The seconds is in that variable. When you process the data you start from array address 1 as seconds.
edit
It's more complex than that. I'll get back.Edited by BobD 2015-04-10
BobD
Posted: 11:39pm 08 Apr 2015
try that. I put two statements in labelled NEW
[code]
ReadTime:
Dim RTCbuff(8)
I2C Close
BCDTEMP = RTCBuff(0) ' NEW
BCDtoDec BCDTEMP ' NEW
BCDtoDec BCDTEMP
BCDtoDec BCDTEMP
BCDtoDec BCDTEMP
BCDtoDec BCDTEMP
BCDtoDec BCDTEMP
Time$ = T$
Date$ = D$
print t$, " ", d$
'Convert to Decimal
[/code]
Are you using a Maximite or a Micromite chip?
If the latter, then any reason for not using one of the supported RTC chips or modules? Then it is as simple as RTC SETTIME and RTC GETTIME....
See page 53 of the manual, if you are using a MicroMite chip, that is.
easterly81
Posted: 03:58am 09 Apr 2015
  BobD said   You read your data into RTCBuff(0) and incrementing. The seconds is in that variable. When you process the data you start from array address 1 as seconds.
edit
I tried that with no success.
I am using the ds1307 I have 4 of them already.
Posted: 07:03am 09 Apr 2015
The syntax should be "I2C Read i2caddr, 0, 8, RTCBuff()" and not RTCBuff(0)
twofingers
Posted: 09:08am 09 Apr 2015
This applies to µM:
  Quote  The syntax should be "I2C Read i2caddr, 0, 8, RTCBuff()" and not RTCBuff(0)
Syntax for MAXIMITES:
  Quote   The data can be in a one dimensional array. The subscript does not have to be zero and will be honoured; also bounds checking is
performed. Example: I2C WRITE &H6F, 1, 3, ARRAY(0)
(p. 57, Maximite manual 4.5)
Older libraries were often written for Maximites.
btw. the DS3231 is a better RTC, IMHO.
edit: I just found out RTCBuff(0) should also work on MicroMites.
RTCBuff() is of course the better style!
Edited by twofingers 2015-04-10
easterly81
Posted: 09:26am 09 Apr 2015
Thanks I will try that when I get home. I thought the RTCBuffer(0) seemed strange () makes sense.
Do the control bits in the middle of the data effect the data read? I have seen on other c based libraries were they use masks to deal with this. For example
Wire.requestFrom(clockAddress, 7);
// A few of these need masks because certain bits are control bits
second = bcdToDec(Wire.read() & 0x7f);
minute = bcdToDec(Wire.read());
// Need to change this if 12 hour am/pm
hour = bcdToDec(Wire.read() & 0x3f);
dayOfWeek = bcdToDec(Wire.read());
dayOfMonth = bcdToDec(Wire.read());
month = bcdToDec(Wire.read());
year = bcdToDec(Wire.read());
twofingers
Posted: 11:27am 09 Apr 2015
This works for my DS3231 rtc:
' RTC.ReadTime for Mircomite MMbasic 4.6B/DS3231 RTC on 0x68 (also for DS1307)
' Begin DEMO
option base 0
? Time$, Date$
RTC.ReadTime
? Time$, Date$
END ' DEMO
Sub RTC.ReadTime 'from DS3231 I2C
Local float i2caddr = &h68 ' my DS3231 I2C address
Local RTCbuff(7)
Local string sec$, min$, hours$, DOW$, day$, month$, year$, T$,D$
I2C write I2caddr, 0, 1, 0
I2C Read i2caddr, 0, 7, RTCbuff() ' Read Time, fills the buffer
' or ... RTCbuff(0)
I2C Close
'capture I2C-error here?
sec$ = Str$(BCDtoDec(RTCBuff(0)))
min$ = Str$(BCDtoDec(RTCBuff(1)))
hours$ = Str$(BCDtoDec(RTCBuff(2)))
DOW$ = Str$(BCDtoDec(RTCBuff(3))) 'day of week?? always=0?
day$ = Str$(BCDtoDec(RTCBuff(4)))
month$ = Str$(BCDtoDec(RTCBuff(5)))
year$ = Str$(BCDtoDec(RTCBuff(6)) + 2000 )
Time$ = hours$+":"+min$+":"+sec$
Date$ = day$+"/"+month$+"/"+year$
' Convert to Decimal
Function BCDtoDec(BCDTEMP As integer) As integer
BCDtoDec = Fix(BCDTemp / 16) * 10
BCDtoDec = BCDtoDec + (BCDTEMP And &hF)
End Function
Normally Micromite users will get the Time/Date from DS1307 with RTC GETTIME.
  Grogster said   If the latter, then any reason for not using one of the supported RTC chips or modules? Then it is as simple as RTC SETTIME and RTC GETTIME....
easterly81
Posted: 11:48am 09 Apr 2015
I just ordered one on amazon ds3231 will be here on sat,now I am just curious.
Here is a post that someone used the ds1307 and it looks like it worked. It likes very similar I don't really she the difference. Can anyone Point out the difference.
http://www.thebackshed.com/forum/forum_posts.asp?TID=6810&KW=ds1307
Posted: 03:05pm 09 Apr 2015
The 1307 is drifty - it's time will be wrong after a few weeks to a month. Not by a HUGE amount, but it does drift.
The 3231 or 3232 have built-in laser-trimmed crystal oscillator, and are accurate to the second over years on end, in theory.
If you don't care about absolute accuracy, then the 1307 is fine, but if you want the clock to stay accurate over months on end, then the 3231 or 3232 is the way to go.
easterly81
Posted: 07:08pm 09 Apr 2015
I agree the ds1307 drifts i have seen it on other projects I have done. I am glad I have ordered the ds3231 and cannot wait to experiment with it. To be honest the code from the first post is what i have used in my current project and it works to set the micromites internal clock with this statement:
D$ = month$+"/"+day$+"/"+year$
time$ = T$
Date$ = D$
Then i print to the LCD with the time$, date$
I was concerned this method would gain error over time since the d31307 was only used to set the MM clock on initial power up. I was using this as a band-aid because when tried to print the T$ or D$ I would get mostly gibberish with the occasional correct reading. BTW the code was different then below i had a sub that pulled the RTC data and formatted it. It is just strange to me when the ds1307 is called once to set the mm clock it works 100% of the time.
Here is the code i have been working on if curious. Sorry it is a rather mess but working kinda.
I originally thought the issue was coming from the I2C LCD. I dont believe this is the case because the test code i used from post 1 does not function either. I should just give it up, get some sleep and await the ds3221, but that just not my style.
Dim PWM1
Dim PH
dim Tempr
Dim RTCbuff(8)
dim pwmdir
LCDI2C_Init 63,1,0,2,3
LCDI2C_BacklightOn
'I2C Close
BCDtoDec BCDTEMP
BCDtoDec BCDTEMP
BCDtoDec BCDTEMP
BCDtoDec BCDTEMP
BCDtoDec BCDTEMP
time$ = T$
Date$ = D$
Main:
'pwm1= pwm1 +5
if pwm1 = 100 then
pwmdir = 1
end if
if pwm1 = 0 then
pwmdir = 0
end if
if pwmdir = 0 then
pwm1= pwm1 + .1
end if
if pwmdir = 1 then
pwm1= pwm1 - .1
end if
readTEMP
ReadPH
LCDI2C 1,1,"Temperature "
LCDI2C 1,13, str$(tempr*1.8+32)
LCDI2C 2,1, "Time "
LCDI2C 2,6, time$
LCDI2C 3,1, "Date "
LCDI2C 3,6, date$
LCDI2C 4,1, "PH "
LCDI2C 4,4, str$(ph)
pwm 1,10000,PWM1
print pwm1
pause 250
goto Main
'Get PH
sub ReadPH
SETPIN 2, AIN
PH =PIN(2)*3.5+.21
end sub
'TEMP
sub readTEMP
tempr= DS18B20(14)
end sub
'Get Ime and format it from DS1307
'Convert BCD to Decimal
' Print String to LCD
SUB LCDI2C(LineNum,CharPos,Text$)
LOCAL I
IF LineNum=1 THEN I=(&H80 + CharPos-1)
IF LineNum=2 THEN I=(&HC0 + CharPos-1)
IF LineNum=3 THEN I=(148 + CharPos-1)
IF LineNum=4 THEN I=(212 + CharPos-1)
LCDI2C_CMD(I)
FOR I=1 TO LEN(Text$)
LCDI2C_DATA(ASC(MID$(Text$,I,1)))
NEXT I
END SUB
' Clear LCD
SUB LCDI2C_Clear()
LCDI2C_CMD(&H01)
END SUB
' INITIALIZE LCD
SUB LCDI2C_Init I2CAddr,NibPos,RSBitNo,ENBitNo,BLBitNo
'Backlight Control bit
DIM LCDI2C_BackLight
LCDI2C_BackLight=2^BLBitNo
'Current Backlight state - default to ON
DIM LCDI2C_LCDBackLight
LCDI2C_LCDBackLight=LCDI2C_BackLight
'I2C Bus Address
DIM LCDI2C_I2CAddr
LCDI2C_I2CAddr=I2CAddr
'RS Control bit
DIM LCDI2C_RSDataMask
LCDI2C_RSDataMask=2^RSBitNo
'EN Control Bit
DIM LCDI2C_EMask
LCDI2C_EMask=2^ENBitNo
'Save if P0~P3 or P4~P7 bits of PCF8574 port
DIM LCDI2C_NibPos
LCDI2C_NibPos=NiBPos
'Start I2C
I2C OPEN 400,100
'%0011---- %0011---- 8-bit / 8-bit
LCDI2C_CMD(&H33)
'%0011---- %0010---- 8-bit / 4-bit
LCDI2C_CMD(&H32)
' Byte commands - To configure the LCD
' Display Format
' 4bit mode, 2 lines, 5x7
' 001LNF00
' %00101000
LCDI2C_CMD(&H28)
' L : 0 = 4-bit Mode 1 = 8-bit Mode
' N : 0 = 1 Line 1 = 2 Lines
' F : 0 = 5x7 Pixels 1 = N/A
' Setup Display
' Display ON, Cursor On, Cursor Steady
' 00001DCB
' %00001110
LCDI2C_CMD(&H0C)
' D : 0 = Display Off 1 = Display On
' C : 0 = Cursor Off 1 = Cursor On
' B : 0 = Cursor Steady 1 = Cursor Flash
' Setup Cursor/Display
' Inc Cursor Cursor Move
' 000001IS
LCDI2C_CMD(&H06)
' I : 0 = Dec Cursor 1 = Inc Cursor
' S : 0 = Cursor Move 1 = Display Shift
LCDI2C_CMD(&H01)
'Turn Off LCDBacklight
LCDI2C_BackLightOff()
END SUB
' Close the I2C LCD
SUB LCDI2C_Close()
'Close the I2C Bus
I2C CLOSE
END SUB
' Turn Backlight On
SUB LCDI2C_BacklightOn
LCDI2C_LCDBacklight=LCDI2C_Backlight
LCDI2C_WireWrite(0)
END SUB
' Turn Backlight Off
SUB LCDI2C_BacklightOff
LCDI2C_LCDBackLight=&H00
LCDI2C_WireWrite(0)
END SUB
' Send Command Byte to LCD
SUB LCDI2C_CMD(Byte)
'Send Hi Nibble
LCDI2C_DirectSend(Byte AND &HF0)
'Send Low Nibble
LCDI2C_DirectSend((Byte AND &H0F) * 16)
END SUB
' Send Data Byte to LCD
SUB LCDI2C_DATA(Byte)
'Send Hi Nibble
LCDI2C_DirectSend((Byte AND &HF0) OR LCDI2C_RSDataMask)
'Send Lo Nibble
LCDI2C_DirectSend(((Byte AND &H0F) * 16) OR LCDI2C_RSDataMask)
END SUB
' Send Byte to LCD over I2C
' NB, we don't call LCDI2C_WireWrite in this SUB because that results in
' MUCH slower execution time than inlin'ing the I2C Write's
SUB LCDI2C_DirectSend(Byte)
LOCAL B,B1
'Use a copy so that we don't mess up caller's argument
'IS D4-D7 of LCD mapped to P0~P3 of PCD8574 ?
IF LCDI2C_NibPos=0 THEN
B1=Byte\16
ELSE
B1=Byte
ENDIF
'Take EN high, use B 'cos it's quicker than doing the OR's in the I2C Write command itself
B=B1 OR LCDI2C_EMask OR LCDI2C_LCDBacklight
I2C WRITE LCDI2C_I2CAddr,0,1,B
'Take EN Low
I2C WRITE LCDI2C_I2CAddr,0,1,B1 OR LCDI2C_LCDBacklight
END SUB
' Send Byte over I2C
SUB LCDI2C_WireWrite(Byte)
I2C WRITE LCDI2C_I2CAddr,0,1,Byte OR LCDI2C_LCDBacklight
END SUB
Edited by easterly81 2015-04-11
