Forum Index : Microcontroller and PC projects : Windows : KB 3035583 : Be Careful !
| G8JCF Guru Joined: 15/05/2014 Location: United KingdomPosts: 676 |
KB 3035583 was a mysterious "important update, it turns out this update is nagware to try and get punters to update to Windows 10 !! See this Infoworld article http://www.infoworld.com/article/2906002/operating-systems/mystery-patch-kb-3035583-for-windows-7-and-8-revealed-it-s-a- windows-10-prompter-downloader.html After the FTDI automatic update fiasco, one would have thought that MSFT would have been extra careful about not abusing the automatic update mechanism - seems not ! This kind of thing just builds mistrust between MSFT and users - I can already hear @JohnS typing in "I told you so !!" Peter The only Konstant is Change |
Did you get bitten by this "Update"? As you say, after the FTDI disaster, you'd think they would know better... I have Automatic Updates set to download only, but let me decide which to apply, that way, I can stop updates like this one running, if there is a warning about it such as there is here. Smoke makes things work. When the smoke gets out, it stops! |
No, I have the same settings as you, and if an update looks suspicious, eg it's NOT security related, I go to MSFT's KB and check it out. This one stank as soon as I looked it up on MSFT's KB - the wording was so vague, and the wording reminded me of an update for Windows 8 which was nagware about upgrading to Windows 8.1 which crippled my uncle's machine - I had to use restore points to get rid of it. Right click on this update and select "Hide". Peter The only Konstant is Change |
With your update settings you may be better off with the following setting. You then have choices about when to download. Some of those updates are pretty hefty these days. I have MS Orifice 13 and it regularly hits 1 GB + of updates but even without that several hundred meg per machine is possible. Also there is no point in downloading an update if you don't want to install it. I forgot to say that I put KB3035583 on a test machine and it installed and uninstalled without any dramas and didn't even need a reboot. |
