Forum Index : Microcontroller and PC projects : ASCII Video Terminal
| Barawitzka Newbie Joined: 31/03/2015 Location: AustriaPosts: 4 |
Hi all, i successfully implemented the AVT to the AVR CP/M Stick Project. Even Wordstar 4.0 works with it, but not really full with DEC VT100. It's not a problem of missing VT100 ESC sequences, there are missing ANSI sequences. Working with a Terminal Emulation VT100 I see what is missing. The colour sequences of ANSI are not implemented. I'm not very experienced in video programming of the PIC32MX250F128B. Do anyone see a chance to implement a colour mixing for this AVT too? Thanks for all input. Boris |
There are two problems with this. The first its that due to the way the video is generated the ASCI Video Terminal is monochrome only, the second is that the VT100 did not have any codes for colour because it was monochrome also. If I knew what codes for colour WordStar is generating I could modify the Terminal's firmware to intercept the colour codes and throw them away so that they do not clutter up the display. Geoff Geoff Graham - http://geoffg.net |
Hi Geoff, thank you for this quick answer. On the screen i see only fragments like "[0;1m"(ANSI CODE for yellow) and "[m"(ANSI CODE for reset colour". I will try to find the complete code through the wschange.com . My hope was that the MX250F128B has two further free ports free fast enough to mix up colour, but that isn't the fact. Thank you for this great project. It is astonishing what you are performing magic with only one pic. Boris |
Hi Geoff, i hope i found all: here are the codes: ESC[m reset videoattr. ESC[7m sign invers ESC[30m sign black ESC[31m sign red ESC[32m sign green ESC[33m sign yellow ESC[34m sign blue ESC[35m sign magenta ESC[36m sign cyan ESC[37m sign white ESC[40m background black ESC[41m background red ESC[42m background green ESC[43m background yellow ESC[44m background blue ESC[45m background magneta ESC[46m background cyan ESC[47m background white thank you for your help Best Regards Boris |
Hi Geoff, here i found from annother source following base VT100 commands: Current VT-100 Code list ESCc Terminal Reset ESC[m Turn off character attributes '' ESC[0m Turn off character attributes ESC[1m Turn bold character on ESC[7m Turn reverse video on ESC[30m Foreground black ESC[31m Foreground green ESC[32m Foreground red ESC[33m Foreground yellow ESC[34m Foreground blue ESC[35m Foreground magenta ESC[36m Foreground cyan ESC[37m Foreground white ESC[40m Background black ESC[41m Background green ESC[42m Background red ESC[43m Background yellow ESC[44m Background blue ESC[45m Background magenta ESC[46m Background cyan ESC[47m Background white ESC[A Move cursor up '' ESC[nA Move cursor up n lines ESC[B Move cursor down '' ESC[nB Move cursor down n lines ESC[C Move cursor right '' ESC[nC Move cursor right n lines ESC[D Move cursor left '' ESC[nD Move cursor left n lines ESC[H Move cursor to upper left corner '' ESC[;H Move cursor to upper left corner ESC[line;columnH Move cursor to screen location v,h ESC[f Move cursor to upper left corner '' ESC[;f Move cursor to upper left corner '' ESC[line;columnf Move cursor to sceen location v,h '' ESCD Move/scroll window up one line '' ESC[D Move/scroll window up one line '' ESCL Move/scroll window up one line (undocumented) ESC[L Move/scroll window up one line (undocumented) '' ESCM Move/scroll window down one line ESC[M Move/scroll window down one line '' ESCK Clear line from cursor right ESC[K Clear line from cursor right '' ESC[0K Clear line from cursor right '' ESC[1K Clear line from cursor left '' ESC[2K Clear entire line ESC[J Clear screen from cursor down '' ESC[0J Clear screen from cursor down '' ESC[1J Clear screen from cursor up ESC[2J Clear entire screen '' ESC[0c Terminal ID responds with [?1;0c for VT-100 no options '' ESC[c Terminal ID responds with [?1;0c for VT-100 no options '' Esc[value@ Insert one character '' Esc[valueP Delete one character ESC[?25h Cursor on ESC[?25l Cursor off Best Regards Boris |
Just visiting the world of VT100 emulation after 100 years, and annoyed by the dancing cursor. Has anyone had this work? Or other simple alternatives? Esc[?25l doesn't seem to work in either MMchat or TerraTerm. Thanks Phil. |
