Local Time 08:57 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Interrupts
palcal
Posted: 11:03pm 24 Mar 2015
In MM basic if I have an interrupt
eg: SetPin 6, INTH,XXXX
Can I execute the interrupt in software with
Pin 6=1
Pause 5
Pin 6=0
Would I need a pause.
Paul.
Posted: 11:17pm 24 Mar 2015
Just do this:
[code]
SetPin 6, INTH, MySub
'call the sub when needed from software
MySub
SUB MySub
'Do your stuff here when an interrupt on pin 6 occurs OR when it is called from software.
END SUB
[/code]
Edited by TZAdvantage 2015-03-26
palcal
Posted: 11:33pm 24 Mar 2015
Does not the interrupt have to end with 'Ireturn'
or is it OK to branch to a defined sub.
Read the manual on interrupts and could not find anything.
Paul.Edited by palcal 2015-03-26
disco4now
Posted: 01:27am 25 Mar 2015
Its OK to call a SUB, use END SUB and not IRETURN to end it.
The 4.6 Manual details it with the SETPIN command description. (there are two sections for SETPIN one after the other in the command section.
Gerry
F4 H7FotSF4xGT
Posted: 02:19am 25 Mar 2015
For new programs it would be better to use
[code]
SUB MySub
END SUB
[/code]
instead of the old way
[code]
MySub:
return 'or ireturn
[/code]
The old way is more open to subtle errors as a program can execute code in a subroutine when not all code paths are terminated and obviously your case where a interrupt routine has to be used from code.
Posted: 02:34am 25 Mar 2015
I am confused - are we saying it is now possible to terminate an interrupt with 'End Sub'??
WW
Posted: 02:43am 25 Mar 2015
Yes, that was introduced together with defined functions and subroutines.
I think the micromites had that from the beginning, the maximite in later versions.
It might be good to remove that from the manual and always use defined subroutines for interrupts.
Posted: 03:03am 25 Mar 2015
  TZAdvantage said  It might be good to remove that from the manual and always use defined subroutines for interrupts.
Excellent point. The old code (calling a label) can be left in but deprecated.
Posted: 03:09am 25 Mar 2015
I missed that one - always used 'iReturn'!!
Guess it is time I re-read the manual
palcal
Posted: 11:23am 25 Mar 2015
Thanks all that's a big help.
Paul.
Posted: 01:27pm 25 Mar 2015
  WhiteWizzard said   I missed that one - always used 'iReturn'!!
It DOES depend on what you are doing.
If you KNOW FOR A FACT that the code will only EVER be called by an interrupt, then IRETURN is fine, I would think. Having interrupts call a subroutine that ends with END SUB is a nice combination though, if you need to be able to call the same code without it having to be summoned from an interrupt.
Only problem I see with calling a sub from an interrupt, is that if the code happens to be in that very same sub, when the interrupt calls it again - would that perhaps not cause some odd and difficult to track bugs in code operation?
