Local Time 06:32 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximite auto start
larny
Posted: 06:00pm 28 Feb 2015
I have a Mono Maximite & I would like it to run a programme whenever the power is turned on.
I intend to use it to monitor the Pump Controller of my Solar Hot Water system. I want to work out how it works in case the PIC in it ever fails & I have to write a programme for a replacement PIC.
The point is that - it will be outside, so I don't want to have a Keyboard & Monitor out there to start the programme running every morning (I intend to do it for several days in order to cover a reasonable range of weather).
Any assistance will be appreciated.
BobD
Posted: 06:09pm 28 Feb 2015
  larny said   I have a Mono Maximite & I would like it to run a programme whenever the power is turned on.
This is from page 3 of the manual
[quote]
On the Maximite MMBasic will look for a file on startup called “AUTORUN.BAS” in the root directory of the internal flash drive (A:) then the SD card (B:). If the file is found it will be automatically loaded and run, otherwise MMBasic will print a prompt (“>”) and wait for input. [/quote]
larny
Posted: 09:02pm 28 Feb 2015
[quote]
Thanks very much BobD, much appreciated.
I have only just returned to Maximite after about a 2 year absence.
I didn't think to check the manual.
larny
Posted: 09:03pm 28 Feb 2015
Thanks very much BobD. Much appreciated.
I have only just recently returned to Maximite after about a 2 year absence.
I didn't think to check the manual.Edited by larny 2015-03-02
