Forum Index : Microcontroller and PC projects : MMbasic DHT21 bug?
| MipsyKing Newbie Joined: 12/02/2015 Location: ItalyPosts: 17 |
Hello, i'm experiencing a strange behaviour with MMbasic v4.6 and a DHT21 temperature-humidity senor. (this one: ebay 1) I connect sensor exactly like in the manual (with the pull-up resistor) 2) I program a simply loop reading sensor every 2 seconds. (no other functions called) 3) I get a long sequence of 1000,1000... 1000,1000 and only sometimes 2 or 3 REAL values, then a lot of 1000 again, and so on. 4) When values are OK, they show right temperature and humidity, so sensor is working. 5) Powering sensor at 3,3 or 5V doesnt change the problem. 6) the same sensor, connected to a PIC16f628 programmed by me in machine language is working without problems. After all, I think problem may/seems to be (?) the MMbasic too critical about timings (?), or reading too near transation fronts instead in the middle (?), or disturbed by other interupts (?) |
...anyother is experiencing same unreliable behaviour from MMbasic and DHT2X sensor? |
There is a bug in V4.6. At temperatures below about 25 degrees C and above 42 degrees, the error occurs. http://www.thebackshed.com/forum/forum_posts.asp?TID=7369&PN =5 The latest version of MM Basic V4.6B has fixed the bug. Jim VK7JH MMedit |
| robot Newbie Joined: 28/01/2015 Location: AustraliaPosts: 2 |
MipsyKing, There is a known bug that was corrected in MMBasic 4.6B You can download this version at http://geoffg.net/micromite.html Unfortunately you have to flash the micro again. |
Many thanks to both! I didnt suspect about this because i've flashed my firmware just a week ago! But I was also in a "forced pause", caused by my PICKIT 3 incompatibily, so I didnt realize I was actually flashing a "surpassed" version. Thank again. |
