Local Time 05:44 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LCD 40X4 problem.
kermess
Posted: 09:50am 23 Feb 2015
Hello everyone.
I go to the forum to ask if anyone has had this problem and know how it has solved.
I am using this LCD
RayStar Optronics LCD 40x4 RC4004A
http://www.tme.eu/es/Document/6de177fca5cf350474d79235ec3715 33/RC4004A-FHW-CSX.pdf
Decoding signal "Enable", En1 and En2 using this application note.
http://www.thebackshed.com/forum/forum_posts.asp?TID=6723&KW =74HC00
And this is the simple program.
'LCD 40X4 RAYSTAR RC4004A
'D0,D1,D2,D3 and R/W to GND
'Power LCD +5V.
'EN ----En1 and En2 with 74HC00 "decoder" in Pin(10)
'LCD INIT D4,D5,D6,D7,RS,EN
'LCD 14,15,21,22, 9, 7
'...EN (Pin10) (74HC00) En1/En2
SetPin 10,dout
'Init LCD lines 1 and 2
Pin(10)= 0
LCD init 14,15,21,22, 9, 7
LCD close
'Init LCD lines 3 and 4
Pin(10)= 1
LCD close
Pin(10)= 0
Pin(10)= 0
LCD 1,4,"Line 1, Pos 4":LCD 1,18,"Line 1, Pos 18"
LCD 2,7,"Line 2, Pos 7":LCD 2,25,"Line 2, Pos 30"
Pin(10)= 1
LCD 1,4,"Line 3, Pos 4":LCD 1,20,"Line 1, Pos 20"
LCD 2,2,"Line 4, Pos 2":LCD 2,17,"Line 2, Pos 17"
'etc....
LCD close
End
Lines one, two "OK".
Lines three, four "ERROR" writing.
If I change the value of the Pin (10) then
Lines one, two "ERROR" writing.
Lines three, four "OK".
Ideas .. ??
Thank you very much.
kermess
Posted: 10:33am 23 Feb 2015
Use two I/O lines, one for E1 and one for E2 to eliminate the 74HC00 to start with.
Posted: 12:20pm 23 Feb 2015
The LCD command only works with displays using a certain controller chip and it sounds as if your display uses a different controller. There is no real answer to this problem as there are many different displays with a wide variety of controllers - and it is not possible to support them all.
The solution probably is to find a compatible display.
Posted: 12:22pm 23 Feb 2015
the correct link to the datasheet is:
the module does seem to contain two separate controllers, which makes life complicated. you likely need to initialize both controllers simultaneously for correct operation with the micromite, but only send data to one or the other when writing text. the use of LCD close on just one controller will likely confuse mmbasic.
i'd suggest using 3 pins to route the E signals correctly. lets say you want to keep using pin 7 as the EN output, while pins 25 and 26 route the signal:
connect E1 to pin 25.
connect E2 to pin 26.
connect a 4k7 resistor between pins 7 and 25.
connect a 4k7 resistor between pins 7 and 26.
the above arrangement means that, with pins 25 and 26 both configured as open collector outputs, the signal to E1 or E2 can be individually suppressed by setting the appropriate pin (25 or 26) to 0. if set to 1, then the EN signal is allowed through.
in your code, do something like this:
setpin (25, DOUT, OC)
setpin (26, DOUT, OC)
pin(25) = 1
pin(26) = 1
LCD init 14,15,21,22, 9, 7 ' initialize both controllers
pin(25) = 1 ' enable writing to first controller
pin(26) = 0 ' disable writing to second controller
LCD 1,4,"Line 1, Pos 4": LCD 1,18,"Line 1, Pos 18"
LCD 2,7,"Line 2, Pos 7": LCD 2,25,"Line 2, Pos 30"
pin(25) = 0 ' disable writing to first controller
pin(26) = 1 ' enable writing to second controller
the above code is totally untested, and has not been anywhere near a micromite - it may contain small syntax errors, etc. but, in principal, i believe the method should work.
btw, a similar routing method could be applied to other signals, for instance to split the output of a single comm port across several receiving devices (similar in use to the SerialTx custom function).
rob :-)
Posted: 12:30pm 23 Feb 2015
geoff:
"The ST7066U has pin function compatibility with the HD44780, KS0066 and SED1278 that allows the user to easily replace it with an ST7066U"
http://www.sitronix.com.tw/sitronix/product.nsf/Doc/ST7066U? OpenDocument
the problem is not so much the command set, but more one of the signal routing, and being able to talk to what is effectively two LCD modules attached to a single micromite at the same time.
rob :-)Edited by robert.rozee 2015-02-24
Posted: 12:55pm 23 Feb 2015
Interesting way of doing things - the two LCD controllers in one display idea(one for each of the two lines, I guess?)
Why do it that way when you already HAVE four-line LCD controllers?
Is it just cost(cheaper) do you think?
srnet
Posted: 09:51pm 23 Feb 2015
  Grogster said   Interesting way of doing things - the two LCD controllers in one display idea(one for each of the two lines, I guess?)
Possibly because the standard HD44780 command to set the cursor position has DB7 set, and thus only allows for 128 display positions ?
kermess
Posted: 08:03am 24 Feb 2015
Thank you all.
It's working now.
The answer was the two resistors and the uMite [output/exits] in open colector mode.
At the beginning I wasn't sure the the initialization was correct for both drivers but it seems to work pretty well.
Here it is the source code of the working system.
'By David Perez from Barcelona (Spain)
'D4,D5,D6,D7,En1,En2
'14,15,21,22, 25, 24
'Power LCD +5V.
'LCD INIT D4,D5,D6,D7,RS,EN ("En1+En2")
'LCD 14,15,21,22, 9, 7 ("25+24")
'Pin(25)uMite to - En1(LCD) with 4k7 resistor to Pin(7)uMite
'Pin(24)uMite to - En1(LCD) with 4k7 resistor to Pin(7)uMite
SetPin 25,dout,oc
SetPin 24,dout,oc
'Enable En1,En2
Pin(25)= 1
Pin(24)= 1
'Disable (En1,En2)
Pin(25)= 0
Pin(24)= 0
'Enable (En1) Line 1 and 2
Pin(25)= 1
Pin(24)= 0
LCD 1,2,"Line 1, Pos 2":LCD 1,23,"Line 1, Pos 23"
LCD 2,7,"Line 2, Pos 7":LCD 2,25,"Line 2, Pos 25"
'Enable (En2) Line 3 and 4
Pin(25)= 0
Pin(24)= 1
LCD 1,5,"Line 3, Pos 5":LCD 1,20,"Line 3, Pos 20"
LCD 2,2,"Line 4, Pos 2":LCD 2,27,"Line 4, Pos 27"
'Disable (En1,En2)
Pin(25)= 0
Pin(24)= 0
LCD close
end
Un saludo
DavidEdited by kermess 2015-02-25
Posted: 10:17am 24 Feb 2015
Congratulations, great result.
Posted: 11:13am 24 Feb 2015
reading that it now works has absolutely made my day. it is really nice to see a positive result, and what you have achieved will most certainly help others in future
congrats,
rob :-)
