Forum Index : Microcontroller and PC projects : Cfunction for RGB LED IC...
| Zonker Guru Joined: 18/08/2012 Location: United StatesPosts: 772 |
Good afternoon Gent's.. I seem to remember someone had come up with a CFunction for This RGB LED but, I can't seem to locate it.. I wanted to use it as a controllable light source for a gauge backlighting project... Was wondering if the CFunction would allow chaining the lamps together in a string and how many deep you could go... Thanks for any info on this...!
Edit: - I did find This Post But not any CFunction for it... |
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1162 |
Yeah, I am waiting too!
Plasma, what's going on? Did you reached anything new with the WS2812? Frank |
Humm.... Maybe it's time for me to give this CFunction stuff a try... We know basically what needs to happen... You pass the intended pin to drive, and your first RGB 656 pattern shifted out to the drive pin... Then, (I guess) you would have a small basic subroutine pass the CFunction a group of bytes that match the number of IC RGB lamps you have strung together to form the group. The CFunction would push just one color control byte and let the user change the outer "basic" subroutine stuff... I will try to find the "how do you do this" stuff that Matherp posted here somewhere... I'll be back after some head scratchin....
Oldbitcollector![]() Senior Member Joined: 16/05/2014 Location: United StatesPosts: 172 |
+1 I think Plasma's got this working, but perhaps a little code-shy? My Propeller/Micromite mini-computer project. |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12071 |
I've ordered one of these , should make a fun present for my granddaughter
It should arrive tomorrow so I'll knock up a Cfunction then. I have to say though this device has the most stupid data format I've ever seen - why isn't the frame length for a "1" the same as for a "0"? I can only think the little processor is running flat out and these timings are just a reflection of the code it can execute. |
| plasma Guru Joined: 08/04/2012 Location: GermanyPosts: 437 |
i send some code to matherp and i hope it helps. unfortunately i cant help much beause the rescued hd is corupt and i cant remember all the code. it shows the timingstructure and some settings i hope it helps. thx |
Typical of me being too headstrong - I'd just coded it from scratch . Looks good on the scope but waiting for some hardware to test. The code should support any number of LEDs but the RTC will lose 1msec for each refresh of each 29 LEDs in the string (3 refreshes/second with 72 LEDs in the string will lose 9msec / second). No loss of time if the number of LEDs is 28 or less .
If anyone wants to try the code while I wait for some hardware here it is, runs on 28 or 44 pin 170s. Get rid of the spaces in the 2 long strings (p28$ and p44$) that the BB software has put in: OPTION DEFAULT NONE OPTION EXPLICIT CPU 48 const Green=0 const Red=1 Const Blue=2 const NUMLEDS=28 ' number of LEDs in chain const WS2812pin=16 ' pin to use for output DIM integer buffer(NUMLEDS*3-1) dim INTEGER colours(2,NUMLEDS) dim integer i,portnum,pinnum ' for i=0 to NUMLEDS-1 'set up some example colours colours(green,i)=&HFF colours(red,i)=&HFF colours(blue,i)=&HFF next i ' setpin WS2812pin,dout i=getpin(WS2812pin,portnum,pinnum) ' Do i=pulses(NUMLEDS,portnum,pinnum,colours(),buffer()) LOOP ' end ' 'number of LEDs, PIC port numer (0=A..2=C), Pin number within the port, array of colour codes, buffer array used by the CFunction ' CFunction Pulses 00000000 8fa30010 24020001 8ccc0000 01826004 8c860000 00067840 01e67821 8ca60000 14c20003 8ca50004 10a00009 3c0ebf88 24020002 14c20003 3c0ebf88 50a00007 25cd6234 25cd6034 10000005 25ce6038 25cd6134 10000002 25ce6138 25ce6238 34058000 3c02bf80 ac450600 51e00012 8c820004 00605821 00005021 2409ffff 8ce80000 01602821 24020007 00483006 30c60001 a0a60000 2442ffff 1449fffb 24a50001 254a0001 24e70008 154ffff4 256b0008 8c820004 5c400007 3c02bf80 1440000c 3c05bf80 8c820000 2c42001d 14400008 3c02bf80 8c460c00 3c05ffff 24a57fff 00c52824 ac450c00 10000006 8c850000 8ca20c10 2c420065 1040fffd 00000000 8c850000 000510c0 00052940 00a21023 10400025 00003821 3c05bf80 00673021 90c60000 10c0000f 00000000 adcc0000 aca00610 8ca60610 2cc60019 14c0fffd 00000000 adac0000 aca00610 8ca60610 2cc6000d 14c0fffd 00000000 1000000e 24e70001 adcc0000 aca00610 8ca60610 2cc60005 14c0fffd 00000000 adac0000 aca00610 8ca60610 2cc60014 14c0fffd 00000000 24e70001 14e2ffe1 00673021 10000003 8c830004 00001021 8c830004 5c600008 3c03bf80 14600009 00000000 8c830000 2c63001d 14600005 00000000 3c03bf80 8c640c00 34848000 ac640c00 adac0000 03e00008 00001821 End CFunction ' 'long long Pulses(long long *numleds, long long *portname,long long *mypin,long long parray[], unsigned char sarray[]){ ' #define tmr4 *(volatile unsigned int *)0xbf800C10 //timer 1 configuration register ' #define tmr4con *(volatile unsigned int *)0xbf800C00 //timer 1 configuration register ' #define tmr1con *(volatile unsigned int *)0xbf800600 //timer 1 configuration register ' #define tmr1 *(volatile unsigned int *)0xbf800610 //timer 1 counter ' unsigned int nextcol,index,k,bpos,pin=1<<*mypin,current_ticks=0; ' unsigned int numcols=*numleds*3; ' unsigned char ch; ' unsigned int volatile * mysetport; ' unsigned int volatile * myclearport; ' if(*portname==0) { ' mysetport=(volatile unsigned int *)0xbf886038; ' myclearport=(volatile unsigned int *)0xbf886034; ' } ' if(*portname==1) { ' mysetport=(volatile unsigned int *)0xbf886138; ' myclearport=(volatile unsigned int *)0xbf886134; ' } ' if(*portname==2) { ' mysetport=(volatile unsigned int *)0xbf886238; ' myclearport=(volatile unsigned int *)0xbf886234; ' } ' tmr1con=0x8000; //turn on timer at full speed ' index=0; ' for(k=0;k<numcols;k++){ //move the data into a single dimensional array that we can step though in even time ' nextcol=parray[k]; ' for(bpos=0;bpos<8;bpos++){ ' sarray[index]=(nextcol>>(7-bpos)) & 1; ' index++; ' } ' } ' if(*numleds > 28) { //Decide how to avoid RTC interrupts ' tmr4con &= 0xFFFF7FFF; //turn off the real time clock if it is going to interfere ' } else { ' while(tmr4>100); //synchronise with the RTC to avoid interrupts ' } ' k=*numleds * 24;; //get the number of bytes to output ' for (index=0;index<k;index++){ //step through the input data ' // Note the timer settings are not obvious as the execution of the loop elongates the low pulses ' if (sarray[index]){ ' *mysetport=pin; ' tmr1=0; ' while(tmr1<25); //Tune for the 700ns pulse ' *myclearport=pin; ' tmr1=0; ' while(tmr1<13); //Tune for the 600ns pulse ' } else { ' *mysetport=pin; ' tmr1=0; ' while(tmr1<5); //Tune for the 350ns pulse ' *myclearport=pin; ' tmr1=0; ' while(tmr1<20); //Tune for the 800ns pulse ' } ' } ' if(*numleds > 28) tmr4con |= 0x0008000; //turn the clock back on ' *myclearport=pin; //Set the output low to create the reset pulse which loads the data ' return index; '} ' ' uses the pin number to get the port number and the pin number on the port by reference to the Device ID ' function getpin(MMpin as integer,portnum as integer,pinnum as integer) as integer const P28$="N/AA00A01B00B01B02B03N/AA02A03B04A04N/AB05B06B07B08B09 N/AN/AB10B11B12B13B14B15N/AN/A" const P40$="B09C06C07C08C09N/AN/AB10B11B12B13A10A07B14B15N/AN/AN/A A00A01B00B01B02B03C00C01C02N/AN/AA02A03A08B04A04A09C03C04C05 N/AN/AB05B06B07B08" local integer i local a$ length 3 i=(MMpin-1)*3 +1 if (peek(word &HBF80F220) and &HFFFFFFF) = &H6610053 then if MMpin>=1 and MMpin<=28 then a$=mid$(p28$,i,3) else a$="N/A" endif else if MMpin>=1 and MMpin<=40 then a$=mid$(p40$,i,3) else a$="N/A" endif endif if a$="N/A" then getpin=0 else portnum=asc(left$(a$,1))-65 pinnum=val(right$(a$,2)) getpin=1 endif end function ' |
Awesome Pete..!! Wow, I am going to look at this tomorrow after work... I have a sparkfun RGB LED and will get it connected up and try it out... Now where IS that thing...? |
Hey, I wonder if we can string enough together to make a crude LED screen.. Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Looks like they are already available. (Don't ask me why I looked them up) Panel Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
They come ready "stringed" but quite pricey, also the power requirement starts to get quite high with larger numbers. Refreshing a unit like this would take about 3.5msec |
Those LEDs are quite amazing. They could even be incorporated onto a MicroMite board as a status LED to give some visual output to micromites or other modules. Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Lads, Some interesting derivatives HERE Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
