Local Time 04:42 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Distance and Direction GPS calculations
srnet
Posted: 10:09am 26 Jan 2015
I have some formulae that I used in a Mikrobasic project to calculate the distance and direction between two sets of GPS derived latitudes and longtitudes.
The calculation required the use of a ARCCOS and ARCSIN function.
I note MMbasic has ARCTAN, but are the ARCCOS and ARCSIN functions do-able ?
Or indeed has anyone run up such a calculation using MMbasic as is ?
Extreme accuracy not vital, +\- 1 degree and maybe within 10m per km.
BobD
Posted: 10:24am 26 Jan 2015
Have a look here. There are probably other examples. You could try this search.
brucepython
Posted: 10:47am 26 Jan 2015
I'm no expert, but give these a try:
arcsin(x) = 2*ATN(x/(2+SQR(1-x*x)))
arccos(x) = 2*ATN(SQR(1-x*x)/(1+x)) [NB only if -1<x<=1]
BruceEdited by brucepython 2015-01-27
srnet
Posted: 08:24pm 26 Jan 2015
Thanks guys, thats all I needed to know for now, it does indeed look possible so very re-assuring.
The idea was to receive telemetry from a LoRa based high altitude balloon tracker and have a simple portable receiver (fitted with a GPS) tell you where and how far away the balloon was, including after it had landed, thus providing a simple means of locating it.
Edited by srnet 2015-01-28
