Local Time 04:42 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM2: DHT22 Is there an issue?
disco4now
Posted: 11:46pm 21 Jan 2015
I am new to the Micromite and have been playing with a DHT22 temperature and humidity sensor on one of Micks NanoMites.
It worked first go but has been intermittent since it first went for a few minutes.
It sometimes works and other times show 1000/1000 as the result, indicating it either not there or giving invalid data. I figured it was a faulty DHT22 but only have one so could not prove it.
After I got my $10 Logic Analyzer I looked at the signal from the DHT22 (AM2302 is same thing) and after downloading the data sheet could understand the signaling, and it all appeared to be good, but MMBasic saying 1000/1000.
The data comes back as 40 bits, 2 * 8 bits for temp and 2 * 8 bits for humidity and 8 bits as parity. The parity is the sum of the previous 4 * 8 bits.
The binary values coming back are divided by 10 to give the temperature and humidity to 1 decimal place.
If I breath on the sensor it starts working but if temperature falls below 25.6 degrees is stops working.
I am suspicious that MMBasic 4.6 is getting the parity calculation wrong if there is a carry from bit(7) when the previous 4 * 8 bits are added. i.e it says the data is invalid.
Has anyone else seen this? Can anyone check the source code to see how MMBasic calculates the parity bits for the DHT22 command?
Gerry
F4 H7FotSF4xGT
Justplayin
Posted: 09:34am 22 Jan 2015
  Quote  Has anyone else seen this?
I setup a DHT22 on a breadboard during the 4.6 beta testing and it worked every time. When I updated to 4.6 release version, I have not been able to get it to work reliably. I have not spent any real time checking into it other than replacing the jumper wires twice (one long set and one short set) and trying another DHT22. Hopefully later today I'll have a chance to re-flash my Micromites and test with 4.6a and a older version.
  Quote  If I breath on the sensor it starts working but if temperature falls below 25.6 degrees is stops working.
I'll have to see if the temperature effects my sensor too. It was a little warmer while the beta test was going on (about 27C), right now it's about 21C in my office.
--Curtis
palcal
Posted: 11:14am 22 Jan 2015
I have one working in my workshop with V4.6a but here in Nth Qld. the temperature has not been below 25 for maybe 2 months. I'll turn on the air conditioner today and give it a test.
Paul.
Posted: 11:55am 22 Jan 2015
I can confirm a problem.
V4.6 Beta 25 works OK
Beta 26, V4.6 and V4.6a all fail.
Room temperature a pleasant 22 degrees.
I didn't play with CPU speed.
palcal
Posted: 12:52pm 22 Jan 2015
Just checked mine and can confirm a problem when temp. goes below 25.6C.
V4.6a
Paul.
@ TassieJim. at 22 deg. I would be wearing a jumper.Edited by palcal 2015-01-23
Justplayin
Posted: 01:46pm 22 Jan 2015
Yep! Tested with beta 16 and it was working down to 11.5 with no problems (surrounded sensor with bottles of water from the fridge). Release versions 4.6 and 4.6a both failed. I also tried heating the sensor with a heat gun while testing the different versions of firmware and the warmer temperatures did not effect whether the DHT22 worked or not.
--Curtis Edited by Justplayin 2015-01-24
disco4now
Posted: 03:05pm 22 Jan 2015
Thanks for all that testing guys. I'll stop wriggling leads trying to make it go for now.
Is there a way to report to Geoff or does he look here?
I have asked for a copy of the source to see if I can see how it works.
Gerry
F4 H7FotSF4xGT
Posted: 04:43pm 22 Jan 2015
  palcal said   below 25.6C.
That looks like a misread of the returned value when it gets down to a single byte
Posted: 05:05pm 22 Jan 2015
Damn, it sounds like a bug. I must have tested it in the warmer weather. Give me a couple of days and I will see if I can track it down.
palcal
Posted: 01:05pm 23 Jan 2015
Tried to see what would happen if the humidity dropped down to 25%. So I heated the sensor in an enclosed environment to lower the humidity, but found as soon as the temp. reaches 42 deg. the same problem occurs.
Paul.
disco4now
Posted: 01:34pm 23 Jan 2015
I think it is really a combination of the temperature and humidity. They come across as 4 * 8 bits.e.g.
0000 0000 high byte for temp
1111 1100 low byte for temp (252 is 25.2)
0000 0010 high byte for humidity
0000 0001 low byte for humidity. 51.3%
1111 1111 checksum byte
If when these are added up for the check byte there is a carry out to the next highest bit (ie bit(8)) that it fails. When temperature is below 25.5 the chance of a humidity byte not causing a carry is low.
The above combination of 25.2 deg and 51.3% humidity would probably be OK as no carry is generated in the checksum.
Gerry
F4 H7FotSF4xGT
palcal
Posted: 02:18pm 23 Jan 2015
Interesting, because when I said it failed at 42 deg. the humidity at the time was 51.3%
Paul.
