Local Time 03:01 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Latest MK II mmbasic
atmega8
Posted: 04:48am 12 Jan 2015
in the last days there was a thread, where Geoff showed the latest MMBASIC ( Integer Problem, Display Option).
I cannot find it again.
Please give me a Link for Download.
THX
Lou
Posted: 06:59am 12 Jan 2015
atmega8,
Is this the thread you were looking for ??
Here
Lou
atmega8
Posted: 07:37am 12 Jan 2015
No,
the latest Update IS only some days old...
bigfix
Posted: 07:54am 12 Jan 2015
You find the thread here:
http://www.thebackshed.com/forum/forum_posts.asp?TID=7329&PN =1&TPN=1
cheers
Guenter
atmega8
Posted: 08:09am 12 Jan 2015
This Iis not a working Link.
No chance with IOS device;-(((
Thank you.
twofingers
Posted: 08:47am 12 Jan 2015
Hallo Atmega,
plz search for 2015-01-11_050958_Micromite_V4.6a.zip
Michael
atmega8
Posted: 08:58am 12 Jan 2015
this is exactly the Version i was looking for.
Thank you very much.
V4.6A
Posted: 01:42pm 12 Jan 2015
You only need to reflash to 4.6A if you need the composite video output on a VT100 setup to work. That's all that 4.6A fixes - everything else is the same. Don't flash this version for general purpose use, as it was specific to the one issue mentioned in that thread. IE: If you DON'T need the EDIT command etc to work correctly on a VT100 in Composite video output mode, then you don't need to worry about this alpha until a later final.
atmega8
Posted: 07:38pm 12 Jan 2015
Grogster,
it fixes also a Bug when 2 Integers > 30 Bit are compared!
  Grogster said   You only need to reflash to 4.6A if you need the composite video output on a VT100 setup to work. That's all that 4.6A fixes - everything else is the same. Don't flash this version for general purpose use, as it was specific to the one issue mentioned in that thread. IE: If you DON'T need the EDIT command etc to work correctly on a VT100 in Composite video output mode, then you don't need to worry about this alpha until a later final.
