Local Time 02:11 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C pullup voltage?
Bizzie
Posted: 08:57pm 05 Jan 2015
I have a logging system which has been successfully working for nearly 3 years. It consists of a PicAxe 20X2 acting as the master scanning up to 5 PA 20X2's using I2C.
I would like to replace the master with a CGColorMax2 so I can get access to the data over the Internet and also be able to write the data to SD.
What voltage should I pull the two I2C signal lines to? The MM pins are 5V tolerant so I assume it would be 5 volts.
Rob White
Posted: 09:01pm 05 Jan 2015
5V or 3.3V depending on the requirements of the other devices.
JimEdited by TassyJim 2015-01-07
