Local Time 20:23 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GPS calculation / Electride / Fortran
isochronic
Posted: 02:55am 31 Dec 2014
What distance do you get, calculating it between Melbourne and Sydney ?
I get 712.8965 km but it seems a bit short, can anyone with a navsat etc confirm ?
Here is the data etc (rounded a little)
Distance = acos( sin(lat1) * sin(lat2) + cos(lat1) * cos(lat2) *
cos(long2 - long1) )
It has been constituted over several lines.
PROGRAM inpgpsdist;
C;
DOUBLE xo, yo, xd, yd, r ;
DOUBLE qf ;
WRITE "Start" ;
r = 57.29577951 ;
WRITE "What is the Origin latitude ?" ;
READ xo ;
WRITE ;
WRITE "What is the Origin longitude ?" ;
READ yo ;
WRITE ;
WRITE "Destination latitude ?" ;
READ xd ;
WRITE ;
WRITE "Destination longitude ?" ;
READ yd ;
WRITE ;
WRITE ;
WRITE "Origin latitude is ", xo ;
WRITE "Origin longitude is ", yo ;
WRITE "Destination latitude is ", xd ;
WRITE "Destination longitude is ", yd ;
xo = xo / r ;
yo = yo / r ;
xd = xd / r ;
yd = yd / r ;
qf = dist(xo,yo,xd,yd) ;
FORMAT (A,F6.1,A,/) ;
WRITE (6,0) "Distance is ", qf, " km" ;
END ;
C;
DOUBLE FUNCTION dist ( a, b, c, e ) ;
DOUBLE l, m, z, t, r ;
r = 57.29577951 ;
m = SIN a * SIN c ;
l = ( b - e );
l = COS l ;
t = COS a * COS c * l ;
z = m + t ;
z = ACOS z ;
z = z * 1.852 * 60.0 * r ;
dist = z ;
RETURN ;
END ;
Start
-37.814107
144.96328
-33.8674869
151.2069902
Origin latitude is -37.81410700
Origin longitude is 144.96328000
Destination latitude is -33.86748690
Destination longitude is 151.20699020
Distance is 712.9 km
Edited by chronic 2015-01-01
BobD
Posted: 04:45am 31 Dec 2014
Google Earth gives it as 713.79 but I wasn't exactly on your co-ordinates. Close enough to verify your calcs.
Posted: 04:47am 31 Dec 2014
This formula is supposed to be mathematically equivalent but less subject to rounding errors:
d=2*asin(sqrt((sin((lat1-lat2)/2))^2 +
cos(lat1)*cos(lat2)*(sin((lon1-lon2)/2))^2))
cwilt
Posted: 11:09am 31 Dec 2014
What kind of precision are you looking for? There are several different formulas floating around.
Posted: 11:35am 31 Dec 2014
These are the functions I use for distance and bearing:
function distance(lat1,long1,lat2,long2)
lon1=long1/57.29577951
lat1=lat1/57.29577951
lon2=long2/57.29577951
lat2=lat2/57.29577951
if (lat1=lat2) and (long1=long2) then
distance = 0
else
distance = acs(sin(lat1)*sin(lat2)+cos(lat1)* cos(lat2)*cos(lon1-lon2))* 6371
endif
end function
function bearing(lat1,long1,lat2,long2)
bearing = 0
else
fa=SIN(lon2-lon1)*COS(lat2)
fb=COS(lat1)*SIN(lat2)-SIN(lat1)*COS(lat2)*COS(lon2-lon1)
bearing=(atn(fa/fb))* 57.29577951
if fb<0 then bearing = 180+ bearing else if fa<0 then bearing = 360 + bearing
endif
end function
Lat and long are in decimal degrees
Degrees south are negative
Degrees West are negative
I have not tested them on recent releases of MMBasic but they should be OK still.
The routines are part of my Satellite location program from a few years ago.
Posted: 12:30pm 31 Dec 2014
I just realized that I am missing a function for ASC()
This breaks the distance function. All I have to do now is find where I had that function....
With all this type of calculations, the limits of 32 bit floating point maths will come into play.
I have added the missing function and changed the name of distance to dist so it doesn't conflict with a keyword in the micromite's
input "Latitude ";lat1
input "Longitude ";lon1
print
input "Latitude ";lat2
input "Longitude ";lon2
print "Distance = ";dist(lat1,lon1,lat2,lon2)
print "Bearing = ";bearing(lat1,lon1,lat2,lon2)
end
function dist(lat1,long1,lat2,long2)
dist = 0
else
dist = acs(sin(lat1)*sin(lat2)+cos(lat1)* cos(lat2)*cos(lon1-lon2))*6371
endif
end function
bearing = 0
else
endif
end function
function acs(c)
acs = 1.5708 - 2*atn(c/(1+sqr(1-c*c )))
end function
DOS MMBasic Version 4.5
Copyright 2011-2014 Geoff Graham
Latitude ? -37.814107
Longitude ? 144.96328
Latitude ? -33.8674869
Longitude ? 151.2069902
Distance = 713.402
Bearing = 57.7023
Edited by TassyJim 2015-01-01
isochronic
Posted: 03:11am 01 Jan 2015
Thanks all !
As an alternative I also used The formula (thanks matherp) which is called Haversine's I think, it is said to ok with single precision
r = 57.29577951 ;
m = SIN ( ( a - c ) / 2.0 ) ;
l = COS ( a ) * COS ( c ) ;
t = SIN ( ( e - b ) / 2.0 ) ;
z = ASIN ( SQRT ( m * m + l * t * t ) ) ;
dist = 2.0 * z * 1.852 * 60.0 * r ;
RETURN ;
END ;
and it gives the same result eg 712.8965 km
curiouser and curioser !! I havent tried tassys formula yet but I have no doubt the result would be the 713 result a-ok.. . The 6371 figure triggers a memory of being the mean earth radius, although it is actually oblate at the equator so the theoretical trig formulas are probably out a bit..i will try to find an "offical" figure , but i am relieved my arithmetic is ok !!
thanks again
ed-
the calculation is the same but...
using 1.85200 (km/ nautical mile)
* 60.0 (minutes/degree)
* 57.29577951 degrees/radian....gives slightly less than 6371 as the factor
Using the 6371 as the factor instead gives 713.38...so that explains it. So i guess the technical spherical-arc distance is the 712, and the more practical oblate-average is the 713.Edited by chronic 2015-01-02
cwilt
Posted: 07:06am 01 Jan 2015
GIS calculations can be a very deep rabbit hole indeed. Thats why I asked what level of precision you were looking for. My current profession is as a pipeline surveyor and work with Trimble R10 GPS units. Our pipelines typically run over 500 miles and our target accuracy is 1/10 of a foot in that distance. We would often get some weather related down time which gave me time to try different calculation methods and compare to professional measurements.
Haversine is a fast approximation of distance between two points. In my tests it could have errors in excess of 100 feet. Somewhere on one my computers I have a mmbasic library of GPS calculation methods. I will look for it and post it.
Posted: 12:54pm 01 Jan 2015
This is one of the sources I used when developing my routines:
http://www.movable-type.co.uk/scripts/latlong.html
The same formula used in Liberty Basic which has unlimited precision gives the same distance as MMBasic for DOS but different bearings.
MMBasic is out by a few degrees.
I will find out where the errors occur later - the lawn mower is calling me.
Edit: I have just been informed that we are taking the dogs out for a coffee, the lawns can wait.
Edited by TassyJim 2015-01-02
mpep
Posted: 01:07pm 01 Jan 2015
As there appears to be only 1km difference between the 2, over 700km, you are looking at a variation of 0.14%.
Another approach is to use Vincenty's calculations. I am looking into this now for a project I'm working on.
Supposedly even closer than Haversine.
Your maths examples certainly give me hope that everything I want to do is indeed entirely possible. THANKS.
MPepEdited by mpep 2015-01-02
Posted: 03:53pm 01 Jan 2015
I think better after a coffee...
This version has fixed the problem with the wrong bearing.
I was changing global variables within the functions.
I have also used the RAD() and DEG() functions where appropriate.
'input "Latitude ";latitude1
'input "Longitude ";longitude1
'print
'input "Latitude ";latitude2
'input "Longitude ";longitude2
latitude1 = -37.814107
longitude1 = 144.96328
latitude2 = -33.8674869
longitude2 = 151.2069902
PRINT "Distance = ";dist(latitude1,longitude1,latitude2,longitude2)
PRINT "Bearing = ";bearing(latitude1,longitude1,latitude2,longitude2)
END
FUNCTION dist(la1,lo1,la2,lo2)
LOCAL lat1,long1,lat2,long2
lat1 =RAD(la1)
long1=RAD(lo1)
lat2 =RAD(la2)
long2=RAD(lo2)
IF (lat1=lat2) AND (long1=long2) THEN
dist = 0
ELSE
dist = acs(SIN(lat1)*SIN(lat2)+COS(lat1)* COS(lat2)*COS(long1-long2))*6371
ENDIF
END FUNCTION
FUNCTION bearing(la1,lo1,la2,lo2)
lat1 =RAD(la1)
long1=RAD(lo1)
lat2 =RAD(la2)
long2=RAD(lo2)
bearing = 0
ELSE
fa=SIN(long2-long1)*COS(lat2)
fb=COS(lat1)*SIN(lat2)-SIN(lat1)*COS(lat2)*COS(long2-long1)
bearing=DEG(ATN(fa/fb))
IF fb<0 THEN bearing = 180+ bearing ELSE IF fa<0 THEN bearing = 360 + bearing
ENDIF
END FUNCTION
FUNCTION acs(c)
acs = 1.5708 - 2*ATN(c/(1+SQR(1-c*c )))
END FUNCTION
Tested with MMBasic DOS, Maximite 4.5 and micromite 4.6
cwilt
Posted: 05:02pm 01 Jan 2015
  mpep said   As there appears to be only 1km difference between the 2, over 700km, you are looking at a variation of 0.14%.
MPep
You are correct, Vincenty formula will be more accuracte.
isochronic
Posted: 05:34pm 01 Jan 2015
Man... the vincenty site quotes half-a-millimeter !!
I can't even see that detail level..Nice though.
I only tried originally as a test of some substantial arithmetic - then was puzzled as to why the result didn't seem right. ( I have driven from Melbourne to Sydney, it is a day trip, kind of boring, the road distance is quite a bit longer )
Incidentally the single-precision calculation gives a very similar result, it is out by a few meters only, unsurprising - six significant digits is six meters in 6000 km of course but it could add up if repeated I guess.
thanks all, and nice work tassy - that acos function is a new one for me
I'll give my eyes a rest now for a while !!!
isochronic
Posted: 07:43pm 03 Jan 2015
Ok...a site with a vincenty calc using an elliptical earth
indeed gives the 713.78 google earth figure, so I'll take that !! (thanks bobd)
After that it gets wacky - the surface depends on which geoid ,
definition of a surface etc...and some very high level stuff I guess NASA uses,
beautiful but I will definitely leave it to the rocket scientists..eesh.
A last thing, in the function (thanks tassy)
FUNCTION acs(c)
END FUNCTION
the acos is derived from atan as normal, and I guess the subtraction from pi/2 is a chart-rotation -to - trig-rotation conversion...but where is the 2 from ?Edited by chronic 2015-01-05
Posted: 08:33pm 03 Jan 2015
FUNCTION acs(c)
END FUNCTION
Somewhere in the dusty text books, I will have the proof but my head hurts when I try to do too much geometry!
I have a very useful book called "The Basic Handbook 2nd edition" by David A. Lien, published in 1981.
It covers all the popular dialects of Basic and, for most functions, has an entry called "If your computer doesn't have it"
I have been referring to it for the last 30 years and strongly recommend it if you can find a second hand copy.
It is not the same as "The IBM Basic handbook" by the same author.
The 3rd edition is available secondhand at good prices.
BobD
Posted: 08:39pm 03 Jan 2015
chronic
when I did the Google Earth measurement before I wasn't spot on your co-ordinates. I just fixed that (to 6 decimal places) and measured again and it came out to 713.81 at a bearing of 53.92. GE seems to be more accurate than I thought.
Bob
isochronic
Posted: 08:44pm 05 Jan 2015
I used some coordinates in degrees-minutes-seconds instead of decimals when I tried the vincenty method, it was probably a little different. And I typed ...78 when I meant ...79, so it all a-ok...maybe the 6371 radius approximation should be nudged a little for aus. The vincenty javascript is available but I'll leave it I think.
Incidentally the last time I looked in the few Sydney bookshops that have anything remotely technical, the cooking section was about three times larger than then all I.T.!..only 1 book even on C...the net has taken over I think.
cdeagle
Posted: 05:02am 06 Feb 2015
Attached is a zipped file containing an MM BASIC 4.6 implementation of yet another way to calculate the geodesic distance between two locations. It's based on Sodano's algorithm which also determines the azimuth to and from each location.
2015-02-06_145620_demo_geodesic.zip
The following is a typical user interaction with the program for the example given earlier.
program demo_geodesic
first location
please input the geographic latitude
(degrees [-90 to +90], minutes [0 - 60], seconds [0 - 60])
(north latitudes are positive, south latitudes are negative)
? -37,48,50
please input the geographic longitude
(degrees [0 - 360], minutes [0 - 60], seconds [0 - 60])
(east longitude is positive, west longitude is negative)
? 144,57,47
second location
? -33,52,3
? 151,12,25
azimuth 1 to 2 54.0432 degrees
azimuth 2 to 1 230.383 degrees
geodesic distance 713.802 kilometers
redrok
Posted: 04:44am 13 Feb 2015
Hi TassyJim;
Thanks for the code!!!
Just what I was looking for.
However, not for distance on the Earth.
I want to use it for controlling a Heliostat.
Changing Mean_Radius = 180/PI it gives distance in degrees.
In this case the spheroid calculations are perfect for my needs.
Would it be to much to ask you to add another function for
finding the midpoint between the end points.
Do you have a link for the source of these calculations?
Maybe they have the Bisector equations.
Yes, I am aware of the movable-type reference.
However, they use the "atan2(y,x)" function.
Maybe you can show us how to implement the atan2(y,x) function in MMBasic.
This would eliminate the Divide by 0 problems.
redrok
  TassyJim said   I think better after a coffee...
'print
END
lat1 =RAD(la1)
long1=RAD(lo1)
lat2 =RAD(la2)
long2=RAD(lo2)
dist = 0
ELSE
ENDIF
END FUNCTION
lat1 =RAD(la1)
long1=RAD(lo1)
lat2 =RAD(la2)
long2=RAD(lo2)
bearing = 0
ELSE
ENDIF
END FUNCTION
FUNCTION acs(c)
END FUNCTION
cdeagle
Posted: 05:14am 13 Feb 2015
Here's an atan3 function.
function atan3(a, b)
' four quadrant inverse tangent function
' input
' a = sine of angle
' b = cosine of angle
' output
' c = angle ( 0 =< c <= 2 * pi : radians )
pidiv2 = 1.57079632
if (abs(a) < 0.00000001) then
atan3 = (1.0 - sgn(b)) * pidiv2
exit function
else
c = (2.0 - sgn(a)) * pidiv2
endif
if (abs(b) < 0.0000001) then
atan3 = c
exit function
else
atan3 = c + sgn(a) * sgn(b) * (abs(atn(a / b)) - pidiv2)
endif
end function
