Forum Index : Microcontroller and PC projects : miniMaximite f/w update
| mpep Newbie Joined: 09/11/2014 Location: New ZealandPosts: 29 |
Hi all, Been playing around for the first time today. Got past the first hurdle, so all good. My question now involves updating the firmware. I currently have 3.01, so is old. In order to update a miniMaximite, which code do I download, the colour or monochrome version? I suspect monochrome, but want to make sure. MPep |
If you are referring to the unit here, then yes - the monochrome version is what you need. Smoke makes things work. When the smoke gets out, it stops! |
Thanks for confirming that. Much appreciated. |
Updated to v4.5 without problems. |
