Forum Index : Microcontroller and PC projects : Problem with 0
| edu001 Regular Member Joined: 14/07/2014 Location: United KingdomPosts: 82 |
Hi I need to selectively remove the 0's from the output of this array, the format is: If the 0 is the first character (0,9,11) it needs to be read so the output is 0,9,11 if the 0 is the second or third character (3,8,0) it needs to be ignored so the output is 3,8 I have tried (with my limited knowlege of BASIC) everything I can think of Any ideas ? setpin 21, dout pin(21) = 0 dim Out$ '''''''''''''''''''''Primary Alphabet dim STRING A(256) LENGTH 8 'DominoEX16 Primary Alphabet DATA " 1,15, 9"," 1,15,10"," 1,15,11"," 1,15,12"," 1,15,13"," 1,15,14"," 1,15,15"," 2, 8, 8" DATA " 2,12, 0"," 2, 8, 9"," 2, 8,10"," 2, 8,11"," 2, 8,12"," 2,13, 0"," 2, 8,13"," 2, 8,14" DATA " 2, 8,15"," 2, 9, 8"," 2, 9, 9"," 2, 9,10"," 2, 9,11"," 2, 9,12"," 2, 9,13"," 2, 9,14" DATA " 2, 9,15"," 2,10, 8"," 2,10, 9"," 2,10,10"," 2,10,11"," 2,10,12"," 2,10,13"," 2,10,14" DATA " 0, 0, 0"," 7,11, 0"," 0, 8,14"," 0,10,11"," 0, 9,10"," 0, 9, 9"," 0, 8,15"," 7,10, 0" DATA " 0, 8,12"," 0, 8,11"," 0, 9,13"," 0, 8, 8"," 2,11, 0"," 7,14, 0"," 7,13, 0"," 0, 8, 9" DATA " 3,15, 0"," 4,10, 0"," 4,15, 0"," 5, 9, 0"," 6, 8, 0"," 5,12, 0"," 5,14, 0"," 6,12, 0" DATA " 6,11, 0"," 6,14, 0"," 0, 8,10"," 0, 8,13"," 0,10, 8"," 7,15, 0"," 0, 9,15"," 7,12, 0" DATA " 0, 9, 8"," 3, 9, 0"," 4,14, 0"," 3,12, 0"," 3,14, 0"," 3, 8, 0"," 4,12, 0"," 5, 8, 0" DATA " 5,10, 0"," 3,10, 0"," 7, 8, 0"," 6,10, 0"," 4,11, 0"," 4, 8, 0"," 4,13, 0"," 3,11, 0" DATA " 4, 9, 0"," 6,15, 0"," 3,13, 0"," 2,15, 0"," 2,14, 0"," 5,11, 0"," 6,13, 0"," 5,13, 0" DATA " 5,15, 0"," 6, 9, 0"," 7, 9, 0"," 0,10,14"," 0,10, 9"," 0,10,15"," 0,10,10"," 0, 9,12" DATA " 0, 9,11"," 4, 0, 0"," 1,11, 0"," 0,12, 0"," 0,11, 0"," 1, 0, 0"," 0,15, 0"," 1, 9, 0" DATA " 0,10, 0"," 5, 0, 0"," 2,10, 0"," 1,14, 0"," 0, 9, 0"," 0,14, 0"," 6, 0, 0"," 3, 0, 0" DATA " 1, 8, 0"," 2, 8, 0"," 7, 0, 0"," 0, 8, 0"," 2, 0, 0"," 0,13, 0"," 1,13, 0"," 1,12, 0" DATA " 1,15, 0"," 1,10, 0"," 2, 9, 0"," 0,10,12"," 0, 9,14"," 0,10,12"," 0,11, 8"," 2,10,15" DATA " 2,11, 8"," 2,11, 9"," 2,11,10"," 2,11,11"," 2,11,12"," 2,11,13"," 2,11,14"," 2,11,15" DATA " 2,12, 8"," 2,12, 9"," 2,12,10"," 2,12,11"," 2,12,12"," 2,12,13"," 2,12,14"," 2,12,15" DATA " 2,13, 8"," 2,13, 9"," 2,13,10"," 2,13,11"," 2,13,12"," 2,13,13"," 2,13,14"," 2,13,15" DATA " 2,14, 8"," 2,14, 9"," 2,14,10"," 2,14,11"," 2,14,12"," 2,14,13"," 2,14,14"," 2,14,15" DATA " 0,11, 9"," 0,11,10"," 0,11,11"," 0,11,12"," 0,11,13"," 0,11,14"," 0,11,15"," 0,12, 8" DATA " 0,12, 9"," 0,12,10"," 0,12,11"," 0,12,12"," 0,12,13"," 0,12,14"," 0,12,15"," 0,13, 8" DATA " 0,13, 9"," 0,13,10"," 0,13,11"," 0,13,12"," 0,13,13"," 0,13,14"," 0,13,15"," 0,14, 8" DATA " 0,14, 9"," 0,14,10"," 0,14,11"," 0,14,12"," 0,14,13"," 0,14,14"," 0,14,15"," 0,15, 8" DATA " 0,15, 9"," 0,15,10"," 0,15,11"," 0,15,12"," 0,15,13"," 0,15,14"," 0,15,15"," 1, 8, 8" DATA " 1, 8, 9"," 1, 8,10"," 1, 8,11"," 1, 8,12"," 1, 8,13"," 1, 8,14"," 1, 8,15"," 1, 9, 8" DATA " 1, 9, 9"," 1, 9,10"," 1, 9,11"," 1, 9,12"," 1, 9,13"," 1, 9,14"," 1, 9,15"," 1,10, 8" DATA " 1,10, 9"," 1,10,10"," 1,10,11"," 1,10,12"," 1,10,13"," 1,10,14"," 1,10,15"," 1,11, 8" DATA " 1,11, 9"," 1,11,10"," 1,11,11"," 1,11,12"," 1,11,13"," 1,11,14"," 1,11,15"," 1,12, 8" DATA " 1,12, 9"," 1,12,10"," 1,12,11"," 1,12,12"," 1,12,13"," 1,12,14"," 1,12,15"," 1,13, 8" DATA " 1,13, 9"," 1,13,10"," 1,13,11"," 1,13,12"," 1,13,13"," 1,13,14"," 1,13,15"," 1,14, 8" DATA " 1,14, 9"," 1,14,10"," 1,14,11"," 1,14,12"," 1,14,13"," 1,14,14"," 1,14,15"," 1,15, 8" for B = 0 to 255 read A(B) next B getsym sub getsym do Out$ = "EDUPIC DOMINOEX TEST" 'Turn Out$ into ASCII (txtchr) for t = 1 to len(Out$) txtchr=Asc(Mid$(Out$, t, 1)) 'Use txtchr value to read the arrays syma = val(LEFT$(mid$(A(txtchr), 1), 2)) symb = val(left$(mid$(A(txtchr), 4), 2)) symc = val(right$(mid$(A(txtchr), 1), 2)) next t loop Thanks Jed |
There are many ways to achieve what you are after. With the code you have posted here, I would keep the zero's. When you call the sub that outputs the tones, only call it if the value is greater than zero for the second and third sym. do
Out$ = "EDUPIC DOMINOEX TEST" 'Turn Out$ into ASCII (txtchr) for t = 1 to len(Out$) txtchr=Asc(Mid$(Out$, t, 1)) 'Use txtchr value to read the arrays syma = val(LEFT$(mid$(A(txtchr), 1), 2)) symb = val(left$(mid$(A(txtchr), 4), 2)) symc = val(right$(mid$(A(txtchr), 1), 2)) maketone syma ' always send this one if symb > 0 then maketome symb ' only send if not zero if symc > 0 then maketome symc ' only send if not zero next t loop sub maketone symbol ' do whatever to generate tones end sub Not the most efficient code but good enough to get to the next step - making noise. Jim VK7JH MMedit |
Thanks TassyJim If I needed to output the array values directly that would work I should have mentioned that there is a step in between reading the array and creating the tones I have to do this calculation Output = (Previous output +2 +value read from array) MOD 18 So the idea was to filter out the zero's Read the values of syma, symb, symc into an array (don,t know how yet) call it sym Then out = (out +2 +sym) MOD 18 Am I approaching the whole thing in the wrong way ? |
