Forum Index : Microcontroller and PC projects : MM2: 2.4" colour screen updated software
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12069 |
Based on the changes I made to text handling on the 1.8" screen I've retrofitted these to the 2.4" screen - basically converting the pstring function to C. Complete screen write of 8x6 pixel characters (1600 characters on the 240x320 display) has been reduced from over 5 seconds to 660msec. It should be noted that these screens require both a 5V and 3.3V supply. The backlight doesn't come on with 3.3V. 2014-12-15_130401_T24BAS.zip |
| viscomjim Guru Joined: 08/01/2014 Location: United StatesPosts: 925 |
Hi Matherp, could you give an example of which screen you are using for this? Thanks!!!! |
Here you go: Example |
Hmmm.. :) Touchscreen..... MicroSD...... Interesting.... Microblocks. Build with logic. |
