Local Time 22:42 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Quick Q on 4051, 74HC4051
marcwolf
Posted: 02:36pm 01 Dec 2014
HI Folks.
I need a quick answer on this as I'm about to order some parts.
I am working on a very small slim lined package where the number of components is critical.
I will be using these as the 8 sensors http://littlebirdelectronics.com.au/products/force-sensing-r esistor-0-2-circle
Normally when one is feeding an A/D signal to a microcontroller you would create a resistor voltage divider with one end connected to ground and the other to Vcc, and then measure the value between the two resistors.
So in the above case I will also have to fit an extra 8 resistors onto the system.. Unless...
I tie all of one side of the sensors (r1 - r5) to ground, and the other side in to the inputs of the 4051. The A/D output of the 4051 will have the 10k (r6) to Vcc, so that each time I read a sensor it is effectively in a voltage divider configuration.
Or have I gone completely off track.
Many thanks
Marcwolf
Coding Coding Coding..
Keep those keyboards coding..
RAW CODE!!!!!
Posted: 03:15pm 01 Dec 2014
Your circuit above should work OK.
The resistance of the sensors is well above any on resistance of the 4051 so that will not be a problem.
The sensors seem to have a fast response time so switching them on in turn should be OK.
Disclaimer: I have only had a brief read of the data sheets.
marcwolf
Posted: 03:42pm 01 Dec 2014
Many thanks Jim.
Unfortunately this circuit really has to be tiny and I am playing with SMD components and hand soldering. Below is a previous experiment working on the same solution
I did try using one of these
http://www.gravitech.us/i2c128anco.html
But then ran into the issue of needing a resistor for each sensor to complete the resistor network.
In practice only one sensor will be active at a time.
Again thanks for your quick reply..
MarcwolfEdited by marcwolf 2014-12-03
RAW CODE!!!!!
