Forum Index : Microcontroller and PC projects : MM2: MAX7219 8 digit, 7-segment display
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12070 |
If you search for the MAX7219 on ebay and sort by lowest price fairly near the top are some little PCBs with 8 x 7-segment LEDs. Starting price is about £1.63. These are easy to use and program, bright, and good for many simple display purposes. This program demonstrates their use. The main "display" subroutine writes a string to the display using "best-fit" approximations of letters and normal 7-segment numbers. I haven't bothered with any cursor positioning, it is easier just to maintain a complete string in your MM program and then output it. The program truncates strings if required to fit the display. The program uses hardware SPI but I'm going to write a cFunction software version unless anyone has already done it? Another picaxe port done
' ' Example program for using MAX7219 8x 7-segment LED display modules ' option explicit option default integer ' const CS=24 'latch pin for display ' ' MAX7219 Registers const decode=&H09 const intens=&H0A const scanlim=&H0B const shutdwn =&H0C const digtest=&H0F ' MAX7219 Data Constants const Set_Off = 0 const Set_On = 1 const No_Digits = 7 ' Scan limit for digits 0 to 3 = 4 const Dec_Digits = 15 ' decode digits 0 to 3 according to "code B" const Init_Inten = 8 ' 0 (=1/32 PWM on time) to 15 (=31/32 PWM on time) const DigBlank = 15 '"Code B" value to black a digit const DecimPnt = 128 ' Add this value to a digit value/code when we want the decimal point illuminated const Decimal = 10 const Hexadec = 16 ' Array of segment codes for numbers and letter approximations data &H7E, &H30, &H6D, &H79, &H33, &H5B, &H5F, &H70, &H7F, &H7B, &H77, &H1F, &H4E, &H3D, &H4F, &H47, &H5E, &H37 data &H30, &H3C, &H2F, &H0E, &H55, &H15, &H1D, &H67, &H73, &H05, &H5B, &H0F, &H3E, &H1C, &H5C, &H49, &H3B, &H6D ' INIT: dim ch(36),i for i= 0 to 35 read ch(i) next i initmax7219 Main: display("Hello OK") 'test uppercase conversion pause 3000 display("...HELLO") 'test leading fullstops pause 3000 display("Hello world, Hello world, Hello world, Hello world") 'test too long string pause 3000 display(str$(65536,8)) 'Test simple numebr output pause 3000 display(str$(14.88,6,2)) 'test float output pause 3000 display(hex$(1234567890,8)) 'test hex output pause 3000 display("1.2.3.4.5.6.7.8.") 'test max valid string length end ' sub initmax7219 setpin cs, dout pin(cs)=0 SPI OPEN 1000000,3,16 sendcommand(decode,0) 'we want straight access to the elements of the LEDs sendcommand(intens,Init_Inten) sendcommand(scanlim,No_Digits) sendcommand(Shutdwn, Set_on) sendcommand(DigTest, Set_Off) clearMAX7219 end sub ' sub sendcommand(register, command) local i = SPI((register<<8)+command) pulse CS,0.005 end sub ' sub display(textin$) local text$ text$=ucase$(textin$) local i,j,k=0,buff(16) for i=0 to 7 buff(i)=0 endif for i=1 to len(text$) j=asc(mid$(text$,i,1)) if j=32 then buff(k)=0 else if j=46 then 'handle the special case of fullstops/decimal points if k<>0 then if (buff(k-1) and 128)=0 then k=k-1 buff(k)=buff(k) or 128 'set the decimal point on the previous character else buff(k)=128 endif else buff(k)=128 endif else j=j-48 'convert ascii if j>9 then j=j-7 if j>=0 and j<=35 then buff(k)=ch(j) else buff(k)=0 endif endif endif k=k+1 if k>=10 then exit for next i for i=1 to 8 sendcommand(i,buff(8-i)) next i end sub ' sub clearMAX7219 for i=1 to 8 sendcommand(i,0) 'blank the display next i end sub ' |
| viscomjim Guru Joined: 08/01/2014 Location: United StatesPosts: 925 |
Hi Matherp, this is good stuff. Really appreciated. These code examples are really becoming a great addition to MMbasic "libraries" that I keep saving for use in different projects. AWESOME!!! Have you ever used the max7219 with the 8x8 led matrix? This was messed with a while ago on this forum here but never really went too far like creating a scrolling text using 5 or so of these units. I am guessing that with the use of cfuntions, this could actually be a reality. Is this something you could take a look at and see what you think... Thanks again, you are slaying it!!! |
| MM_Wombat Senior Member Joined: 12/12/2011 Location: AustraliaPosts: 139 |
I used the AS1107 when did some testing a while back on 8x8 matrix.. (Maximite V3.2) The link to that thread is here . The chips are similar in output and control. I even got the 3 chips for free as a sample. A small video is in that thread.. [edit] but doesn't work anymore [/edit]
AussieWombat Keep plugging away, it is fun learning But can be expensive (if you keep blowing things up). Maximite, ColourMaximite, MM+ |
| G8JCF Guru Joined: 15/05/2014 Location: United KingdomPosts: 676 |
Members may also be interested in this posting re 7219's. http://www.thebackshed.com/forum/forum_posts.asp?TID=6685&KW =boss Peter The only Konstant is Change |
Oldbitcollector![]() Senior Member Joined: 16/05/2014 Location: United StatesPosts: 172 |
Amazing! (and in MMBASIC no less!) Is someone maintaining a reference to all these great hardware threads? (MMREFERENCE.COM are you still there?) I'll probably start a sticky on the Propellerpowered forums, maybe a thread here is a good idea here as well? Jeff My Propeller/Micromite mini-computer project. |
| aargee Senior Member Joined: 21/08/2008 Location: AustraliaPosts: 255 |
Great point, I was wondering that myself. Matherp is a bit of a powerhouse... good on you!
From Geoffs site (http://geoffg.net/maximite.html ) "The library is managed by Hugh Buckle and is a great resource for beginners and experts alike. If you have written a program for MMBasic and you believe that it is worth sharing, please send it to Hugh at mmlib@geoffg.net and he will add it in. You should also include a description of what the program does for the library index." The latest update is from the 1st Nov, so it looks like it is still active. For crying out loud, all I wanted to do was flash this blasted LED. |
The MMBasic library on Geoff's site contains MMBasic Maximite programs, not Micromite, but I totally agree, a library for MMBasic Micromite code is needed. A couple of days ago, similar points were made in relation to a CFunction library in another thread, as below. It would be nice if both could be in the same place but that may not be workable for the "librarian(s)". Greg |
There are 2 kinds of Library 1) A Collection of things, eg programs, useful functions etc, and this is the kind of library established by Hugh Buckle. There is just 1 library. 2) A software library, eg LCD driver library, and this is the kind of Library which I think we need for stuff like CFunctions, and uMite code. There are many s/w libraries. The distinction between 1) and 2) is that in 1), the librarian acts to collect, store and catalogue what is held in the Library. In 2), the Librarian makes sure that as well as Cataloguing, & storing items, the Librarian also acts to eliminate Name-Space clashes, standardises how the library is documented, standardises calling sequences/methods, standardises use of Global variables etc, ie more Editor than Librarian/Curator. The key purpose being that someone can then take a library off-the shelf, read the documentation, then add it to their program, and be confident that for example the library's use of a Global variable does not clash with the user's program's use of a Global variable, or that the library hasn't set OPTION DEFAULT INTEGER, when the user's program wants to set OPTION DEFAULT FLOAT, ie s/w libraries need to be as neutral as possible. Question : Is this type of library facility, ie 2), required by the Community ? Peter The only Konstant is Change |
I'd certainly think so Peter but it would be good to hear other's opinions, especially Geoff's. Unfortunately I'm very much an amateur on software (hardware too for that matter) so my opinion here is from a limited base. The "Library" subject should definitely have a separate thread anyway so I've PM'd Glenn (Gizmo), our Administartor and asked if he would move the posts from OBC's at 1:55pm on the 2/12/14 to your post above, into a new thread called "Micromite Library" or somesuch. I don't know how else to do this, or if Glenn is available at the moment to do it for us. Greg |
Hi Greg As you say, it will be interesting to hear from others. Peter The only Konstant is Change |
I very much agree also, we do need a library for Micromite programs and "snippets". I believe that it should hold all forms of code (MMBasic as well as CFunctions). Hugh Buckle has done a great job of managing the Maximite library and it involves a lot of work. He has tested most programs and he chases up details (when necessary) from people who have submitted code. He also classifies submissions and indexes them. For the Micromite it would be better if we had a more automated method where people could submit code along with a description and a classification and it would be automatically listed in a database. However, this would take a lot of work to setup. To my mind any library would be worthwhile - even if it is not perfect. I would be the logical person to maintain such a library but these days I am always running out of time and if I took it on I know that I would fail miserably. And I would prefer to spend my time polishing MMBasic. So, we need ideas. Is there someone who wants to take on the job of maintaining a library? Or is there a better way to maintain a library without it being labour intensive? Geoff Geoff Graham - http://geoffg.net |
i could setup a page that can hold code samples and library functions. it would be in a folder type structure where things could be categorized easily. i would prefer that code would be posted through email to prevent spammers. posting directly would be possible but that needs to be behind a login. the info can still be available for anyone, a login would allow trusted people to upload directly without moderation. i already have something setup internally to store datasheets, mostly microchip and parts often used with microcontrollers. the structure can hold other info easily so it would not be too much work. Microblocks. Build with logic. |
| akashh Senior Member Joined: 19/01/2014 Location: IndiaPosts: 115 |
What about a git repository? They seem to have everything needed for this type of sharing, plus files are easily viewable online, so not everyone needs to download the entire repository to get the snippet he needs. Just a thought. |
Current discussion of this thread has been moved to the thread "Micromite Library". Greg |
