Local Time 23:31 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Date routines for the Micromote Mk2
Posted: 03:49pm 29 Nov 2014
With the introduction of 64 bit integers, using Unix time has become relatively painless.
These routines were written with an early beta of 4.6 and there are some areas that can be updated. I was going to wait for 4.6 final before doing the updates but I thought that some of the routines will go well with jman's NTP code.
The main program loop simply takes a date and time then converts it to Julian and Unix then back again as a check.
The subroutines can be used for doing time/date maths.
The odd one is the routines for converting to Julian Date. We need a double float to store the number but that is not available so it is stored as a string.
The STR$ function has been updated since this code was written and I should be able to get rid of the mystr$ function now.
' date conversion routines
' TassyJim Nov2014
currentdate$= DATE$
currenttime$=TIME$
DO
PRINT currentdate$;" ";currenttime$
IF MM.DEVICE$<>"Micromite MkII" THEN
PRINT "This program will not run on the ";MM.DEVICE$
ENDIF
JD% = Julian(currentdate$)
weekday= (jd%+1) MOD 7 'weekday starts at 0 for Sunday
dayz$=MID$("SunMonTueWedThuFriSatSun",weekday*3+1,3)
Utime%=unixtime%(currentdate$+" "+currenttime$ )
DoY= DayofYear(currentdate$)
Jdate$=JulianDate$(currentdate$+" "+currenttime$ )
PRINT "Day of Week: ";weekday;" ";dayz$
PRINT "Day of year: ";DoY
PRINT "Julian Day : ";JD%
PRINT "Julian Date: ";Jdate$
PRINT "Unix time : ";Utime%
PRINT
PRINT "Reverse J Day : "; JDString$(JD%)
PRINT "Reverse J Date : "; JDateString$(Jdate$)
PRINT "Reverse U time : "; unixDateString$(Utime%)
PRINT
INPUT "New Date (DD/MM/YYYY) or X to quit: ",newdate$
IF UCASE$(newdate$)="X" THEN EXIT DO
IF newdate$<>"" THEN currentdate$=newdate$
INPUT "New Time (HH:MM:SS) : ",newtime$
IF newtime$<>"" THEN
currenttime$=newtime$
ELSE
currenttime$=TIME$
ENDIF
LOOP
END
FUNCTION Julian(datestring$)
' datestring in the format "dd/mm/yyyy" or "dd-mm-yyyy"
' returns the Julian day number corresponding to midday on the given date
' using the Gregorian calendar
LOCAL d, m, y, ff, yo, mo
d=VAL(MID$(datestring$,1,2))
m=VAL(MID$(datestring$,4,2))
y=VAL(MID$(datestring$,7,4))
ff=(14-m)\12
yo=y+4800-ff
mo=m+12*ff-3
Julian = d +(153*mo+2)\5 + 365*yo + yo\4 - yo\100 + yo\400 - 32045
'Julian = d +(153*mo+2)\5 + 365*yo + yo\4 - 32083 ' Julian calendar
END FUNCTION
FUNCTION JulianDate$(datestring$)
' datestring in the format "dd/mm/yyyy hh:mm:ss" or "dd-mm-yyyy hh:mm:ss"
' returns the Julian Date as a string
' requires Julian()
LOCAL h, m, s, JD%, JDtime
JD%=Julian(LEFT$(datestring$,10))
h=VAL(MID$(datestring$,12,2))
m=VAL(MID$(datestring$,15,2))
s=VAL(MID$(datestring$,18,2))
JDtime=(h*3600+m*60+s)/86400
IF JDtime >= 0.5 THEN ' adjust times before midday to the previous day
JDtime = JDtime - 0.5
ELSE
JDtime = JDtime + 0.5
JD% = JD% -1
ENDIF
IF JDtime=0 THEN
JulianDate$=STR$(JD%)+".0"
ELSE
JulianDate$=STR$(JD%)+MID$(mystr$(JDtime),2)
ENDIF
END FUNCTION
FUNCTION DayofYear(datestring$)
' given the date dd/mm/yyyy, returns the day number of the year
' requires Julian()
LOCAL day1, y
day1=Julian(datestring$)
y=VAL(MID$(datestring$,7,4))-1
DayofYear= day1-Julian("31/12/"+STR$(y,4))
END FUNCTION
FUNCTION unixtime%(datestring$)
' returns the unixtime
' requires Julian()
LOCAL h%, m%, s%, JD%
unixtime%=(JD%-2440588)*86400
h%=VAL(MID$(datestring$,12,2))
m%=VAL(MID$(datestring$,15,2))
s%=VAL(MID$(datestring$,18,2))
unixtime%=unixtime%+h%*3600+m%*60+s%
END FUNCTION
FUNCTION unixDateString$(unixt%)
LOCAL unixd%, unixf%, h, m, s, ut$
unixd%=unixt%\86400
unixf%=unixt% MOD 86400
IF unixd%<0 AND unixf%<>0 THEN
unixf%=86400+unixf%
ENDIF
h= unixf%\3600
m= (unixf% MOD 3600)\60
s=(unixf% MOD 3600) MOD 60
ut$=STR$(h,2,0,"0")+":"+STR$(m,2,0,"0")+":"+STR$(s,2,0,"0")
unixDateString$=JDString$(JD%)+" "+ut$
END FUNCTION
FUNCTION JDString$(JD%)
' Given the Julian day number, returns the date as a string
' valid for Gregorian dates after Oct 15, 1582
LOCAL l, n, i, j, d, m, y
l = jd%+68569
n = FIX((4*l)/146097)
l = l-FIX((146097*n+3)/4)
i = FIX((4000*(l+1))/1461001)
l = l-FIX((1461*i)/4)+31
j = FIX((80*l)/2447)
d = l-FIX((2447*j)/80)
l = FIX(j/11)
m = j+2-(12*l)
y = 100*(n-49)+i+l
JDString$=STR$(d,2,0,"0")+"/"+STR$(m,2,0,"0")+"/"+STR$(y,4)
END FUNCTION
FUNCTION JDateString$(JDate$)
' Given the Julian date as a string, returns the date and time as a string
LOCAL dp, JD%
dp=INSTR(JDate$,".")
IF dp >0 THEN
JD%=VAL(LEFT$(JDate$,dp-1))
JDsecs=VAL(MID$(JDate$,dp))*86400
ELSE
JD%=VAL(JDate$)
JDsecs=0
ENDIF
IF JDsecs >= 43200 THEN ' adjust times before midday to the previous day
JDsecs= JDsecs - 43200
JD% = JD% +1
ELSE
JDsecs= JDsecs + 43200
ENDIF
h= JDsecs\3600
m= (JDsecs MOD 3600)\60
s=(JDsecs MOD 3600) MOD 60
JDateString$=JDString$(JD%)+" "+STR$(h,2,0,"0")+":"+STR$(m,2,0,"0")+":"+STR$(s,2,0,"0")
END FUNCTION
FUNCTION mystr$(k)
' needed to print small numbers with 7 digits after decimal point
SELECT CASE k
CASE IS > 0.0001, IS < -0.0001 ' big enough for the normal STR$ function
mystr$=STR$((k),0,7)
CASE IS > 0.0000001
mystr$=STR$((k*1000),0,4)
mystr$="0.000"+MID$(mystr$,3)
CASE IS < -0.0000001
mystr$=STR$((ABS(k)*1000),0,4)
mystr$="-0.000"+MID$(mystr$,3)
CASE ELSE ' really small numbers display as zero
mystr$="0.0000000"
END SELECT
END FUNCTION
twofingers
Posted: 04:59am 30 Nov 2014
Hi Jim,
I like this useful stuff! Thanks a lot!
Michael
paceman
Posted: 01:44pm 30 Nov 2014
Yes, another one for the "I'm gonna need that sometime" box Jim, thanks for that.
Greg
