Local Time 22:37 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM to Raspberry Pi via USB
vk2sja
Posted: 10:55pm 28 Nov 2014
Hi All,
I'm trying to connect my Colour Maximite to a Raspberry Pi via USB. The connection fails. Syslog shows:-
device descriptor read/64, error -32
The CMM is self powered and has just been flashed to MMBasic 4.5
The Pi is a model B (not the just released B+) but has been rpi-updated, apt-get update, apt-get install. The OS is a very recent version of Raspbian in any case.
Tried knocking things back down to USB 1.0 speeds with dwc_otg.speed=1, in /boot/cmdline.txt, still no good.
The Raspberry Pi of course has had a long history with USB problems because the Pi is actually using a USB On The Go chip which normally would see use in a mobile device not a host computer. Tends to trigger all sorts of unexpected bugs.
Anyway, just wondering if anyone has "been there, done that" and had more success than me?
Steve.
Posted: 10:59pm 28 Nov 2014
I had no problems with a B+
You could use a USB-TTL converter and COM1 on the CMM
