Local Time 22:42 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Option Request
jman
Posted: 10:35am 28 Nov 2014
Hi
I was playing with some older code and discovered a problem with the variable
names as some of the different types of variables have the same name
Then after reading the change log properly
" To prevent a common type of programming error variables with the same name but different types are no longer supported. ie, var = 123 : var$ = "abc" will now cause an error"
So the question is would to be possible to make this an option ie on by default and off by setting an OPTION Variabletype off or some thing similar
Anybody else with any thoughts around this ?
Jman
BobD
Posted: 11:09am 28 Nov 2014
I don't care if this is an option or not but I would never knowingly use variables the way you describe. If there is a need to associate variables by name then I would use a descriptive appendage or similar.
Example:
var.one
var.two
Bob
G8JCF
Posted: 11:44am 28 Nov 2014
In a previous post about this subject, http://www.thebackshed.com/forum/forum_posts.asp?TID=7078&PN =3&TPN=5
  robert.rozee said
5. i really hate the new requirements that variable names be unique, ie A and A$ are mutually exclusive names. i really really think that this should be a configurable option the same as "OPTION EXPLICIT" that defaults to being off. amongst other things, it may break existing code.
and
  Geoff said
This is amazing, previously I got a lot of stick because this was allowed!
It was a bad practice and I believe that the critics had a good point. Also the change was necessary to allow variables to optionally not use a type suffix.
It will break a few programs (it broke one of mine) but the change was necessary. And before anyone asks, I don't want to make it yet another option - there are too many already.
Peter
The only Konstant is Change
jman
Posted: 01:52pm 28 Nov 2014
Thanks Peter
I missed that one but I do agree with Robert
Jman
Posted: 02:01pm 28 Nov 2014
Sorry to pester you, and this is a slight digression from topic, but why is having A and A$ NOT being allowed a problem?
Is it more just that it breaks existing code, and you have to port the code to the new version of MMBASIC?
Posted: 03:35pm 28 Nov 2014
If a variable name does not describe what it is used for then the name is wrong.
Having a number and a string version of the same variable is just silly.
It would save so much debugging time when that is not allowed that it will make up the little problem of changing existing code.
A simple search and replace will do the change in a few seconds.
Posted: 03:48pm 28 Nov 2014
OK, I can see the logic in that now. Thanks.
jman
Posted: 04:07pm 28 Nov 2014
  TZAdvantage said   If a variable name does not describe what it is used for then the name is wrong.
Oh Dear this going to be can of worms so this the last post about this for me.
So if we had the hours of the day in a string say hours$ but now we wanted this
as an integer to do some math on then calling the variable hours is silly
really !!!
Jman
Posted: 07:29am 29 Nov 2014
HoursText$
Hours
Problem solved.
Dylan
Posted: 08:07am 29 Nov 2014
Hour$
Hours
Even simpler.
Posted: 08:38am 29 Nov 2014
Dylan; I'm with you on that one - however I see any 'well fuelled eyes' missing the odd '$' and 'S' typo among a big listing!!
