Forum Index : Microcontroller and PC projects : CMM setpin bug?
Hi folks.
Playing around with the CMM now that I have the UBW32 module working, and have found something interesting. MMBASIC version 4.5B for the colour Maximite. SETPIN 19,DOUT PIN(19)=1 ...does not switch on pin 19 as an output. However: SETPIN 19,8 PIN(19)=1 ...does. Smoke makes things work. When the smoke gets out, it stops! |
Interesting, sounds like a bug. I will look at it ASAP. Geoff Graham - http://geoffg.net |
