Local Time 21:53 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Sub Names
jman
Posted: 09:35pm 27 Nov 2014
Hi
Using the Micromite B25
It seems now Sub names are sort of case sensitive
Test:
Print "Hello"
Delay
GoTo Test
Sub DELAY
Pause 1000
The above produces the output below
run
Hello
[4] Delay
Error: Inconsistent type suffix
Test:
Print "Hello"
Delay
GoTo Test
Sub Delay
Pause 1000
The code above produces
Hello
Hello
Hello
Hello
Hello
Hello
Hello
etc....
If you change all the letters to uppercase except the last one it still works as expected.
Test:
Print "Hello"
DELAy
GoTo Test
Sub Delay
Pause 1000
Hello
Hello
Hello
Hello
Hello
Hello
Hello
etc....
Bug Maybe ?
Jman
Posted: 10:04pm 27 Nov 2014
Good find jman - lets see what Geoff says (he's probably fixed it already knowing how fast he works!)
WW
Posted: 10:44pm 27 Nov 2014
Yes, it is a bug and thanks for finding it.
I will fix it in the next beta but the workaround for the moment is to keep the case of a subroutine or function the same throughout your program.
Most grateful,
