Forum Index : Microcontroller and PC projects : MK2: Graphics with flashing text cursor
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12069 |
The rubbish weather is good for something - I can get lots of coding done! This new version puts the screen refresh into an interrupt routine so the refresh command never needs to be called - screen updates should happen within 200msec. The clearscreen routine now just zeroes the local array and lets the interrupt routine update the screen. I've timed wiping the display completely at about 63msec. Two routines "enablecursor" and "disablecursor" do what they say. The cursors work in all screen rotations and all text orientations. The cursor flashes with a cycle time of 800msec to the right of the last character output. It is only repositoned by "pstring" so you need to organise the text output to leave it where you want it. The cursors will only be maintained properly if text is output using the "pstring" subroutine and not the "dchar" primitive so pstring should be used even for single characters. "pstring" also updates the x and y coordinates so an additional string can be output without repositioning the currsor as long as "pstring" is called with the x and y coordinates specified as variables. This should be useful for example displaying user input. There is no "wordwrap" capability The example main program demonstrates all the features of the library and acts as a regression test for me. For live use of course, depending on use, many of the basic graphics routines can be deleted to save space. I haven't drawn up a dependency list but is is pretty obvious from the code. The cFunctions haven't changed. Best Regards Peter ' Monochrome Port of Adafruit graphics library with drivers for i2c SSD1306 display ' ' drawing primitives assume a graphics display where top left is point 0,0 ' 'sub setrot(x) 'sets screen rot: 0=normal,1=invert,2=rotate right,3-rotate left 'sub dcirc(x0,y0,r) 'x,y coordinates of centre,radius 'sub fcirc(x0,y0,r) 'x,y coordinates of centre,radius 'sub dtri(x0,y0,x1,y1, x2,y2) 'three coordinate pairs 'sub ftri (x0,y0,x1,y1, x2,y2) 'three coordinate pairs 'sub dChar(xx,yy,ch,sz,orientation) 'x,y coordinates of top left of first character,ascii character,size,orientation 'sub pstring(xx0,yy0,text$,sz,orientation) 'x,y coordinates of top left of first character,text string,size,orientation 'sub dLine(xx0,yy0,xx1,yy1)' x,y of start line,x,y of end line 'sub dRect(x,y,w,h) 'x,y coordinate of top left,width,height 'sub frect(x,y,w,h)'x,y coordinate of top left,width,height 'sub drndRect(x,y,w,h,r) 'x,y coordinates of top left,width,height,radius of corner 'sub frndRect(x,y,w,h,r) 'x,y coordinates of top left,width,height,radius of corner ' ' These routines just update the memory image of the display ' Use the refresh command to write to the display as required ' 'CFunctions 'unsigned long long ffr(unsigned int *sense,unsigned int *x,unsigned int *y,unsigned int *width,unsigned int *height,unsigned int *rotation,unsigned int *screenwidth,unsigned int *screenheight,unsigned long long sc[]){ 'unsigned long long S_getnextupdate(unsigned char outchar[],unsigned int *startcol,unsigned int *startrow,unsigned int *col,unsigned int *row,unsigned int *maxcols,unsigned int *maxrows,unsigned long long sc[],unsigned long long dd[]){ 'unsigned long long pix(unsigned int *onoff,unsigned int *x,unsigned int *y,unsigned int *rot,unsigned int *wi,unsigned int *ht,unsigned long long p_array[]) 'data cFunction FONT contains the pixel maps for the character set cpu 48 OPTION EXPLICIT OPTION DEFAULT NONE 'option autorun on const normal=0 const inverse=1 const rt_right=2 const rt_left=3 const ON=&B1 const OFF=&B0 const ch=8 const cw=6 ' ' SSD1306 Display specific constants const S_wi=128 const S_ht=64 const S_nr=S_ht\8 'memory is arranged as rows 8 bits high const S_i2caddr=&H3C const S_SETCONTRAST=&H81 const S_DISPLAYALLON_RESUME=&HA4 const S_NORMALDISPLAY=&HA6 const S_DISPLAYOFF=&HAE const S_DISPLAYON=&HAF const S_SETDISPLAYOFFSET=&HD3 const S_SETCOMPINS=&HDA const S_SETVCOMDETECT=&HDB const S_SETDISPLAYCLOCKDIV=&HD5 const S_SETPRECHARGE=&HD9 const S_SETMULTIPLEX=&HA8 const S_SETSTARTLINE=&H40 const S_MEMORYMODE=&H20 const S_COMSCANDEC=&HC8 const S_SEGREMAP=&HA0 const S_CHARGEPUMP=&H8D dim as integer debug=1 ' dim as integer wi,ht,nr,i2caddr,rot_ht,rot_wi,sz,nc,rot,i,j,k,char,AddrOfFo nt dim as integer cursorx=255,cursory=255,cursorsizex,cursorsizey,allowupdate= ON,cursoronoff=on,cursorenable,cursorupdate=0 ' Global variables to enable flashing cursor dim as integer sc(128),dd(128) 'set up arrays for screen map to mimic display init: print "Starting initialisation" print "Using SSD1306" initSdisplay 'initialise the display AddrOfFont=PEEK(CFunAddr FONT) ' setrot(normal) print "starting main" ' dim as integer xforstring,yforstring Main: disablecursor ' test drawing rectangles S_clearsc for i=0 to 3 setrot(i) frect(5,5,10,15) drect(2,2,16,21) next i pause 2000 ' test drawing rounded rectangles S_clearsc for i=0 to 3 setrot(i) frndrect(5,5,10,15,4) drndrect(2,2,16,21,6) next i pause 2000 ' test drawing circles S_clearsc for i=0 to 3 setrot(i) fcirc(10,10,7) dcirc(10,10,9) next i pause 2000 ' test drawing triangles and line drawing S_clearsc for i=0 to 3 setrot(i) ftri(4,4,20,6,12,14) dtri(1,2,24,4,12,17) next i pause 2000 ' test character output and string output at all orientations for sz=1 to 3 enablecursor nc=2 'number of characters in the string I'm using S_clearsc setrot(normal) xforstring=0 yforstring=0 pstring(xforstring,yforstring,"0g",sz,normal) pstring(xforstring,yforstring,"A",sz,normal) pause 2000 pstring(rot_wi-1,rot_ht-1,"0g",sz,inverse) pause 2000 pstring(rot_wi-1,0,"0g",sz,rt_right) pause 2000 pstring(0,rot_ht-1,"0g",sz,rt_left) pause 2000 S_clearsc setrot(inverse) pstring(0,0,"0g",sz,normal) pause 2000 pstring(rot_wi-1,rot_ht-1,"0g",sz,inverse) pause 2000 pstring(rot_wi-1,0,"0g",sz,rt_right) pause 2000 pstring(0,rot_ht-1,"0g",sz,rt_left) pause 2000 S_clearsc setrot(rt_right) pstring(0,0,"0g",sz,normal) pause 2000 pstring(rot_wi-1,rot_ht-1,"0g",sz,inverse) pause 2000 pstring(rot_wi-1,0,"0g",sz,rt_right) pause 2000 pstring(0,rot_ht-1,"0g",sz,rt_left) pause 2000 S_clearsc setrot(rt_left) pstring(0,0,"0g",sz,normal) pstring(0,0,"0g",sz,normal) pause 2000 pstring(rot_wi-1,rot_ht-1,"0g",sz,inverse) pause 2000 pstring(rot_wi-1,0,"0g",sz,rt_right) pause 2000 pstring(0,rot_ht-1,"0g",sz,rt_left) pause 2000 disablecursor pause 4000 next sz goto main end end ' ' SSD1306 Display specific routines ' ' S_update: cursorupdate=cursorupdate+1 if cursorenable and allowupdate and (cursorupdate mod 2) then if cursoronoff then crect(cursorx,cursory,cursorsizex,cursorsizey) cursoronoff=off else cursoronoff=on frect(cursorx,cursory,cursorsizex,cursorsizey) endif endif S_refresh ireturn ' sub initSdisplay 'i2c oled local i as integer wi=S_wi ht=S_ht nr=S_nr i2caddr=S_i2caddr I2C OPEN 400,1000 S_command(S_DISPLAYOFF)' &HAE S_command(S_SETDISPLAYCLOCKDIV)'&HD5 S_command(&H80)'the suggested ratio &H80 S_command(S_SETMULTIPLEX)'&HA8 S_command(&H3F)' S_command(S_SETDISPLAYOFFSET)'&HD3 S_command(&H0)'no offset S_command(S_SETSTARTLINE )'line #0 S_command(S_CHARGEPUMP)'&H8D S_command(&H14) S_command(S_MEMORYMODE)' &H20 S_command(&H00)'&H0 act like ks0108 S_command(S_SEGREMAP OR 1); S_command(S_COMSCANDEC); S_command(S_SETCOMPINS)' &HDA S_command(&H12) S_command(S_SETCONTRAST)'&H81 S_command(&HCF) S_command(S_SETPRECHARGE)'&Hd9 S_command(&HF1) S_command(S_SETVCOMDETECT)'&HDB S_command(&H40) S_command(S_DISPLAYALLON_RESUME)'&HA4 S_command(S_NORMALDISPLAY)'&HA6 S_command(S_DISPLAYON) for i=0 to 127 'force the whole screen to be re-written at the next refresh dd(i)= &HFFFFFFFFFFFFFFFF sc(i)=0 next i s_refresh settick 200,s_update,1 'start the update interupt end sub ' Sub S_Command(command as integer) I2C WRITE i2caddr,0,2,&H00,command end sub ' ' sub S_SendData(Dchar as integer) I2C WRITE i2caddr,0,2,&H40,Dchar end sub ' sub S_refresh local as integer rows=0,cols=0,startrow,startcol,retstatus local outchar$ length 130 S_cursor(0,0) do retstatus=Sgetnextupdate(outchar$,startcol,startrow,cols,row s,wi,nr,sc(),dd()) if retstatus<>0 then S_cursor(startcol,startrow) i2c write i2caddr,0,len(outchar$),outchar$ endif loop while retstatus<>0 end sub ' Sub S_Clearsc local i as integer for i=0 to 127 sc(i)=0 next i end sub ' sub S_Cursor(x as integer,y as integer) S_command(&HB0+y) 'set page address S_command(&H10+(x>>4 and &H0F)) 'set high col address S_command(&H00+(x AND &H0f)) 'set low col address end sub ' ' Generic drawing routines ' sub dcirc(x0 as integer,y0 as integer,r as integer) 'x,y coordinates of centre,radius local as integer f=1-r,ddF_x=1,ddF_y=-2 * r,x=0,y=r,dp dp=pix(ON,x0,y0+r,rot,wi,ht,sc()) dp=pix(ON,x0,y0-r,rot,wi,ht,sc()) dp=pix(ON,x0+r,y0,rot,wi,ht,sc()) dp=pix(ON,x0-r,y0,rot,wi,ht,sc()) do while (x<y) if f>=0 then y=y-1 ddF_y=ddF_y+2 f=f+ddF_y endif x=x+1 ddF_x=ddF_x+2 f=f+ddF_x dp=pix(ON,x0+x,y0+y,rot,wi,ht,sc()) dp=pix(ON,x0-x,y0+y,rot,wi,ht,sc()) dp=pix(ON,x0+x,y0-y,rot,wi,ht,sc()) dp=pix(ON,x0-x,y0-y,rot,wi,ht,sc()) dp=pix(ON,x0+y,y0+x,rot,wi,ht,sc()) dp=pix(ON,x0-y,y0+x,rot,wi,ht,sc()) dp=pix(ON,x0+y,y0-x,rot,wi,ht,sc()) dp=pix(ON,x0-y,y0-x,rot,wi,ht,sc()) loop end sub ' sub dtri(x0 as integer,y0 as integer,x1 as integer,y1 as integer, x2 as integer,y2 as integer) 'three coordinate pairs dLine(x0,y0,x1,y1) dLine(x1,y1,x2,y2) dLine(x2,y2,x0,y0) end sub ' sub ftri (x0 as integer,y0 as integer,x1 as integer,y1 as integer, x2 as integer,y2 as integer) 'three coordinate pairs local as integer a,b,y,dp,last if (y0>y1) then swap(y0,y1) swap(x0,x1) endif if (y1>y2) then swap(y2,y1) swap(x2,x1) endif if (y0>y1) then swap(y0,y1) swap(x0,x1) endif if(y0=y2) then ' Handle awkward all-on-same-line case as its own thing a=x0 b=x0 if(x1<a) then a=x1 else if(x1>b) then b=x1 endif if(x2<a) then a=x2 else if(x2>b) then b=x2 endif dFastHLine(a,y0,b-a+1) exit sub endif local as integer dx01=x1-x0, dy01=y1-y0, dx02=x2-x0, dy02=y2-y0,dx12=x2-x1, dy12=y2-y1, sa=0,sb=0 if(y1=y2) then last=y1 'Include y1 scanline else last=y1-1 ' Skip it endif for y=y0 to last a=x0+sa \ dy01 b=x0+sb \ dy02 sa=sa+dx01 sb=sb+dx02 a=x0+(x1-x0) * (y-y0) \ (y1-y0) b=x0+(x2-x0) * (y-y0) \ (y2-y0) if(a>b) then swap(a,b) dp=ffr(ON,a,y,b-a+1,1,rot,wi,ht,sc()) next y sa=dx12 * (y-y1) sb=dx02 * (y-y0) do while y<=y2 a=x1+sa \ dy12 b=x0+sb \ dy02 sa=sa+dx12 sb=sb+dx02 a=x1+(x2-x1) * (y-y1) \ (y2-y1) b=x0+(x2-x0) * (y-y0) \ (y2-y0) if(a>b) then swap(a,b) dp=ffr(ON,a,y,b-a+1,1,rot,wi,ht,sc()) y=y+1 loop end sub ' sub enablecursor cursorenable=on end sub ' sub disablecursor cursorenable=off cursoroff end sub ' sub cursoroff if cursorx<>255 then 'get rid of any cursor from a previous pstring crect(cursorx,cursory,cursorsizex,cursorsizey) cursoronoff=OFF endif end sub ' sub pstring(xx0 as integer,yy0 as integer,text$ as string,sz as integer,orientation as integer) 'x,y coordinates of top left of first character,text string,size,orientation local as integer i,c,x=xx0,y=yy0 allowupdate=off 'stop the update routine processing the cursor cursoroff if orientation<2 then cursorsizey=(ch-1)*sz cursorsizex=sz else cursorsizey=sz cursorsizex=(ch-1)*sz endif for i=1 to len(text$) c=asc(mid$(text$,i,1)) dchar(x,y,c,sz,orientation) on orientation+1 goto pnormal,pinvert,prtright,prtleft pnormal: x=x+(6*sz) cursorx=x-sz cursory=yy0 goto pcontinue pinvert: x=x-(6*sz) cursorx=x+1 cursory=yy0-(ch-1)*sz+1 goto pcontinue prtright: y=y+(6*sz) cursorx=x-(ch-1)*sz +1 cursory=y-sz goto pcontinue prtleft: y=y-(6*sz) cursorx=x cursory=y+1 pcontinue: next i allowupdate=on xx0=x yy0=y end sub ' sub dLine(xx0 as integer,yy0 as integer,xx1 as integer,yy1 as integer) ' x,y of start line,x,y of end line local as integer dx,dy,x0=xx0,y0=yy0,x1=xx1,y1=yy1,err,ystep,dp,steep=(abs(y1 -y0))>(abs(x1-x0)) if (steep) then swap(x0,y0) swap(x1,y1) endif if (x0>x1) then swap(x0,x1) swap(y0,y1) endif dx=x1-x0 dy=abs(y1-y0) err=dx \ 2 if y0<y1 then ystep=1 else ystep=-1 endif do while x0<=x1 if (steep) then dp=pix(ON,y0,x0,rot,wi,ht,sc()) else dp=pix(ON,x0,y0,rot,wi,ht,sc()) endif err=err-dy if err<0) then y0=y0+ystep err=err+dx endif x0=x0+1 loop end sub ' sub swap (a as integer,b as integer) local as integer t t=b b=a a=t end sub ' sub dRect(x as integer,y as integer,w as integer,h as integer) 'x,y coordinate of top left,wi,ht local as integer a,dp dp=ffr(ON,x,y,w,1,rot,wi,ht,sc()) a=y+h-1 dp=ffr(ON,x,a,w,1,rot,wi,ht,sc()) dp=ffr(ON,x,y,1,h,rot,wi,ht,sc()) a=x+w-1 dp=ffr(ON,a,y,1,h,rot,wi,ht,sc()) end sub ' sub frect(x as integer,y as integer,w as integer,h as integer) 'x,y coordinate of top left,width,height local as integer dp dp=ffr(ON,x,y,w,h,rot,wi,ht,sc()) end sub ' sub crect(x as integer,y as integer,w as integer,h as integer) 'x,y coordinate of top left,width,height local as integer dp dp=ffr(OFF,x,y,w,h,rot,wi,ht,sc()) end sub ' FUNCTION Getchar(char as integer) as integer local as integer i=char<<3 Getchar=PEEK(WORD AddrOfFont+i)+(PEEK(WORD AddrOfFont+i+4)<<32) END FUNCTION ' sub dChar(xx as integer,yy as integer,ch as integer,sz as integer,orientation as integer) 'x,y coordinates of top left of first character,ascii character,size,orientation local as integer i,j,x=xx,y=yy,dp,addr,character character=getchar(ch) 'loads the character on orientation+1 goto dnormal,dinvert,drtright,drtleft dnormal: for i=0 to 5 for j=0 to 7 if (character>>(i*8+j)) and 1 then if (sz=1) then dp=pix(ON,x+5-i,y+j,rot,wi,ht,sc()) else dp=ffr(ON,x+(5-i)*sz,y+(j*sz),sz,sz,rot,wi,ht,sc()) endif else if (sz=1) then dp=pix(OFF,x+5-i,y+j,rot,wi,ht,sc()) else dp=ffr(OFF,x+(5-i)*sz,y+(j*sz),sz,sz,rot,wi,ht,sc()) endif endif next j next i exit sub ' dinvert: for i=0 to 5 'step down the lines for j=0 to 7 if (character>>(8*(5-i)+7-j)) and 1 then if (sz=1) then dp=pix(ON,x-i,y+j-7,rot,wi,ht,sc()) else dp=ffr(ON,x-sz+1-(i*sz),y-sz+1+((j-7)*sz),sz,sz,rot,wi,ht,sc ()) endif else if (sz=1) then dp=pix(OFF,x-i,y+j-7,rot,wi,ht,sc()) else dp=ffr(OFF,x-sz+1-(i*sz),y-sz+1+((j-7)*sz),sz,sz,rot,wi,ht,s c()) endif endif next j next i exit sub ' drtright: for i=0 to 7 'step across the rows for j=0 to 5 if (character>>((5-j)*8+i)) and 1 then if (sz=1) then dp=pix(ON,x-i,y+j,rot,wi,ht,sc()) else dp=ffr(ON,x-sz+1-i*sz,y+(j)*sz,sz,sz,rot,wi,ht,sc()) endif else if (sz=1) then dp=pix(OFF,x-i,y+j,rot,wi,ht,sc()) else dp=ffr(OFF,x-sz+1-i*sz,y+(j)*sz,sz,sz,rot,wi,ht,sc()) endif endif next j next i exit sub drtleft: for i=0 to 7 'step across the rows for j=0 to 5 ' if bits(5-j,i) then if (character>>(8*j+7-i)) and 1 then if (sz=1) then dp=pix(ON,x-i+7,y+j-5,rot,wi,ht,sc()) else dp=ffr(ON,x-i*sz+7*sz,y+j*sz-6*sz+1,sz,sz,rot,wi,ht,sc()) endif else if (sz=1) then dp=pix(OFF,x-i+7,y+j-5,rot,wi,ht,sc()) else dp=ffr(OFF,x-i*sz+7*sz,y+j*sz-6*sz+1,sz,sz,rot,wi,ht,sc()) endif endif next j next i end sub ' sub fcirc(x0 as integer,y0 as integer,r as integer) 'x,y coordinates of centre,radius local as integer dp dp=ffr(ON,x0,y0-r,1,2*r+1,rot,wi,ht,sc()) fcircH(x0,y0,r,3,0); end sub ' sub drndRect(x as integer,y as integer,w as integer,h as integer,r as integer) 'x,y coordinates of top left,width,height,radius of corner local as integer dp dp=ffr(ON,x+r,y,w-2*r,1,rot,wi,ht,sc()) dp=ffr(ON,x+r,y+h-1,w-2*r,1,rot,wi,ht,sc()) dp=ffr(ON,x,y+r,1,h-2*r,rot,wi,ht,sc()) dp=ffr(ON,x+w-1,y+r,1,h-2*r,rot,wi,ht,sc()) dcircH(x+r,y+r,r,1) dcircH(x+w-r-1,y+r,r,2) dcircH(x+w-r-1,y+h-r-1,r,4) dcircH(x+r,y+h-r-1,r,8) end sub ' sub dcircH( x0 as integer,y0 as integer,r as integer,cn as integer) local as integer f=1-r,ddF_x=1,ddF_y=-2 * r,x=0,y=r,dp do while (x<y) if (f>=0) then y=y-1 ddF_y=ddF_y+2 f=f+ddF_y endif x=x+1 ddF_x=ddF_x+2 f=f+ddF_x if (cn and 4) then dp=pix(ON,x0+x,y0+y,rot,wi,ht,sc()) dp=pix(ON,x0+y,y0+x,rot,wi,ht,sc()) endif if (cn and 2) then dp=pix(ON,x0+x,y0-y,rot,wi,ht,sc()) dp=pix(ON,x0+y,y0-x,rot,wi,ht,sc()) endif if (cn and 8) then dp=pix(ON,x0-y,y0+x,rot,wi,ht,sc()) dp=pix(ON,x0-x,y0+y,rot,wi,ht,sc()) endif if (cn and 1) then dp=pix(ON,x0-y,y0-x,rot,wi,ht,sc()) dp=pix(ON,x0-x,y0-y,rot,wi,ht,sc()) endif loop end sub ' sub fcircH(x0 as integer,y0 as integer,r as integer,cn as integer,delta as integer) local as integer dp,f=1-r,ddF_x=1,ddF_y=-2 * r,x=0,y=r do while x<y if f>=0 then y=y-1 ddF_y=ddF_y+2 f=f+ddF_y endif x=x+1 ddF_x=ddF_x+2 f=f+ddF_x if (cn and 1) then dp=ffr(ON,x0+x,y0-y,1,2*y+1+delta,rot,wi,ht,sc()) dp=ffr(ON,x0+y,y0-x,1,2*x+1+delta,rot,wi,ht,sc()) endif if (cn and 2) then dp=ffr(ON,x0-x,y0-y,1,2*y+1+delta,rot,wi,ht,sc()) dp=ffr(ON,x0-y,y0-x,1,2*x+1+delta,rot,wi,ht,sc()) endif loop end sub ' sub frndRect(x as integer,y as integer,w as integer,h as integer,r as integer) 'x,y coordinates of top left,width,height,radius of corner local as integer dp dp=ffr(ON,x+r,y,w-2*r,h,rot,wi,ht,sc()) fcircH(x+w-r-1,y+r,r,1,h-2*r-1) fcircH(x+r,y+r,r,2,h-2*r-1) end sub ' sub setrot(x as integer) 'sets screen rotation: 0=normal,1=invert,2=rotate right,3-rotate left rot=(x and 3) rot_wi=wi rot_ht=ht if x>=2 then rot_wi=ht rot_ht=wi endif end sub ' ' CFunctions ' CFunction font 00000000 00000000 00000000 4f5b3e00 00003e5b 4f6b3e00 00003e6b 7c3e1c00 00001c3e 7e3c1800 0000183c 7d571c00 00001c57 7f5e1c00 00001c5e 3c180000 00000018 c3e7ff00 0000ffe7 24180000 00000018 dbe7ff00 0000ffe7 3a060e00 00003048 79292600 00002629 05050700 0000407f 05253f00 0000407f e73c5a00 00005a3c 1c1c0800 00007f3e 1c3e7f00 0000081c 7f221400 00001422 005f5f00 00005f5f 7f017f00 00000609 89956a00 00000066 60606000 00006060 ffa29400 000094a2 7e040800 00000804 7e201000 00001020 2a1c0800 00000808 2a080800 0000081c 10101000 00001e10 0c1e0c00 00000c1e 3e383000 00003038 3e0e0600 0000060e 00000000 00000000 5f000000 00000000 00070000 00000007 147f1400 0000147f 7f2a1200 0000242a 08646200 00002313 56205000 00003649 07030000 00000008 22410000 0000001c 221c0000 00000041 7f1c2a00 00002a1c 3e080800 00000808 70300000 00000080 08080800 00000808 60600000 00000000 08040200 00002010 49453e00 00003e51 7f400000 00000042 49494600 00007249 494d3300 00002141 127f1000 00001814 45453900 00002745 49493100 00003c4a 11090700 00004121 49493600 00003649 49291e00 00004649 14000000 00000000 34000000 00000040 14224100 00000008 14141400 00001414 22140800 00000041 59090600 00000201 5d594e00 00003e41 11127c00 00007c12 49493600 00007f49 41412200 00003e41 41413e00 00007f41 49494100 00007f49 09090100 00007f09 41517300 00003e41 08087f00 00007f08 7f410000 00000041 413f0100 00002040 14224100 00007f08 40404000 00007f40 1c027f00 00007f02 08107f00 00007f04 41413e00 00003e41 09090600 00007f09 51215e00 00003e41 19294600 00007f09 49493200 00002649 7f010300 00000301 40403f00 00003f40 40201f00 00001f20 38403f00 00003f40 08146300 00006314 78040300 00000304 494d4300 00006159 41414100 0000007f 08102000 00000204 41417f00 00000041 01020400 00000402 40404000 00004040 07080000 00000003 54784000 00002054 44443800 00007f28 44442800 00003844 44287f00 00003844 54541800 00003854 7e090200 00000008 a49c7800 000018a4 04047800 00007f08 7d400000 00000044 403d0000 00002040 28440000 00007f10 7f400000 00000041 78047800 00007c04 04047800 00007c08 44443800 00003844 24241800 0000fc18 2418fc00 00001824 04040800 00007c08 54542400 00004854 3f442400 00000404 40207c00 00003c40 40201c00 00001c20 30403c00 00003c40 10284400 00004428 90907c00 00004c90 544c4400 00004464 36410000 00000008 77000000 00000000 36080000 00000041 02040200 00000201 23263c00 00003c26 a1611200 00001ea1 40207a00 00003a40 54555900 00003854 55794100 00002155 54784200 00002254 54784000 00002155 55794000 00002054 52721200 00000c1e 55555900 00003955 54545900 00003954 54545800 00003955 457c4100 00000000 457d4200 00000002 457c4000 00000001 11127d00 00007d12 2528f000 0000f028 55450000 00007c54 547c5400 00002054 097f4900 00007c0a 49493200 00003249 44443a00 00003a44 48483000 0000324a 41217a00 00003a41 40207800 00003a42 a0a07d00 0000009d 42423d00 00003d42 40403d00 00003d40 ff242400 00003c24 49436600 0000487e fc2f2b00 00002b2f 29f62000 0000ff09 7e090300 0000c088 54794100 00002054 447d4100 00000000 484a3200 00003048 40227a00 00003840 0a0a7200 0000007a 19317d00 00007d0d 292f2800 00002629 29292600 00002629 4d402000 00003048 08080800 00003808 08083800 00000808 c8acba00 00002f10 2834fa00 00002f10 7b000000 00000000 2a142200 00000814 2a140800 00002214 5500aa00 0000aa00 aa55aa00 0000aa55 00ff0000 00000000 10ff0000 00001010 14ff0000 00001414 ff00ff00 00001010 f010f000 00001010 14fc0000 00001414 f700ff00 00001414 ff00ff00 00000000 f404fc00 00001414 17101f00 00001414 1f101f00 00001010 141f0000 00001414 10f00000 00001010 001f1000 00000000 101f1000 00001010 10f01000 00001010 00ff1000 00000000 10101000 00001010 10ff1000 00001010 00ff1400 00000000 ff00ff00 00000000 1f101700 00000000 fc04f400 00000000 17101700 00001414 f404f400 00001414 ff00f700 00000000 14141400 00001414 f700f700 00001414 14171400 00001414 1f101f00 00001010 14f41400 00001414 f010f000 00001010 1f101f00 00000000 001f1400 00000000 00fc1400 00000000 f010f000 00000000 ff10ff00 00001010 14ff1400 00001414 101f0000 00001010 00f01000 00000000 ffffff00 0000ffff f0f0f000 0000f0f0 ff000000 0000ffff 00ffff00 00000000 0f0f0f00 00000f0f 44384400 00003844 4a4a3400 0000fc4a 02060600 00007e02 027e0200 0000027e 49416300 00006355 443c0400 00003844 201e2000 0000407e 7e020200 00000602 e7a59900 000099a5 492a1c00 00001c2a 01724c00 00004c72 4d4d3000 0000304a 78483000 00003048 5a463d00 0000bc62 49490000 00003e49 01017e00 00007e01 2a2a2a00 00002a2a 5f444400 00004444 4a444000 00004051 4a514000 00004044 ff010300 00000000 ff000000 0000e080 6b6b0800 00000808 36243600 00003612 090f0600 0000060f 18180000 00000000 10100000 00000000 ff010100 00003040 01011e00 0000001f 1d171200 00000019 3c3c3c00 0000003c 00000000 00000000 End CFunction ' CFunction pix 00000000 8faa0010 8fab0014 8ce70000 240d0001 10ed000e 8fac0018 50e00008 8ca80000 240d0002 10ed0014 240d0003 54ed0021 8d460000 10000018 8ca20000 00001821 8cc20000 1000001a 00004821 8ca80000 00084027 8d420000 01024021 00001821 8cc20000 00021027 8d650000 00451021 1000000f 00004821 8ca20000 00004821 8cc80000 00084027 8d430000 01034021 10000007 00001821 00021027 8d630000 00431021 00004821 8cc80000 00001821 8d460000 14600004 24050001 0106302b 14c00003 30a500ff 00002821 30a500ff 10a00039 00082d82 8d660000 15200004 24050001 0046302b 14c00003 30a500ff 00002821 30a500ff 50a0002f 00082d82 8c840000 10800016 2404ffff 00002021 15200008 00002821 15200004 24060001 2c460020 10c00004 24060001 10000003 00462004 24060001 00462804 000830c0 01866021 8d860000 00c43025 ad860000 8d860004 00c52025 10000016 ad840004 15200009 2405ffff 15200004 24060001 2c460020 10c00005 24060001 00463004 10000004 00062027 24060001 00463004 00062827 000830c0 01866021 8d860000 00c43024 ad860000 8d860004 00c52024 ad840004 00082d82 00032280 00a42025 00084280 01021021 0048402b 00894821 03e00008 01091821 End CFunction ' CFunction Sgetnextupdate 00000000 27bdffd8 afbe0024 03a0f021 afc40028 afc5002c afc60030 afc70034 24040001 afc40008 8fc40028 24840001 24050040 a0850000 8fc40038 8c840000 afc40004 1000008f 00000000 8fc40034 8c840000 afc40000 10000081 00000000 8fc40000 000420c0 8fc50044 00a42021 8c850004 8c840000 afc40010 afc50014 8fc40000 000420c0 8fc50048 00a42021 8c850004 8c840000 afc40018 afc5001c 8fc40004 03c42021 90850010 8fc40004 03c42021 90840018 10a40064 00000000 8fc50000 8fc4002c ac850000 8fc50004 8fc40030 ac850000 8fc50004 8fc40038 ac850000 8fc50000 8fc40034 ac850000 10000031 00000000 8fc40004 03c42021 90850010 8fc40004 03c42021 a0850018 8fc40000 000420c0 8fc50048 00a43021 8fc40018 8fc5001c acc40000 acc50004 8fc40008 24840001 afc40008 8fc40008 8fc50028 00a42021 8fc50004 03c52821 90a50018 a0850000 8fc40000 24840001 afc40000 8fc40000 000420c0 8fc50044 00a42021 8c850004 8c840000 afc40010 afc50014 8fc40000 000420c0 8fc50048 00a42021 8c850004 8c840000 afc40018 afc5001c 8fc40034 8c840000 24850001 8fc40034 ac850000 8fc40004 03c42021 90850010 8fc40004 03c42021 90840018 10a40007 00000000 8fc50000 8fc4003c 8c840000 00a4202b 1480ffc3 00000000 8fc40034 8c850000 8fc4003c 8c840000 14a40008 00000000 8fc40038 8c840000 24850001 8fc40038 ac850000 8fc40034 ac800000 8fc40008 308500ff 8fc40028 a0850000 8fc20008 8fc40008 000427c3 00801821 10000017 00000000 8fc40034 ac800000 8fc40000 24840001 afc40000 8fc50000 8fc4003c 8c840000 00a4202b 1480ff7b 00000000 8fc40004 24840001 afc40004 8fc50004 8fc40040 8c840000 00a4202b 1480ff6d 00000000 00001021 00001821 03c0e821 8fbe0024 27bd0028 03e00008 00000000 End CFunction CFunction ffr 00000000 27bdffc8 afb50034 afb40030 afb3002c afb20028 afb10024 afb00020 8fb10048 8fa80050 8fb00054 8fb90058 2402ffff a3a20008 2403fffe a3a30009 2403fffc a3a3000a 2403fff8 a3a3000b 2403fff0 a3a3000c 2403ffe0 a3a3000d 2403ffc0 a3a3000e 2403ff80 a3a3000f 24030001 a3a30010 24030003 a3a30011 24030007 a3a30012 2403000f a3a30013 2403001f a3a30014 2403003f a3a30015 2403007f a3a30016 a3a20017 8fa2004c 8c420000 24030001 50430023 8ca30000 50400008 8ca20000 24030002 10430037 24030003 5443006b 25a20007 10000050 8cc20000 00406021 8d030000 0043282b 00004021 10a000f4 00004821 2442ffff 8ce50000 00451021 0043c02b 2463ffff 0078100a 0040c021 8ccf0000 8e020000 01e2182b 106000e8 01e06821 25efffff 8e230000 01e37821 01e2182b 2442ffff 1000004f 0043c00a 00031827 8d020000 00621021 0040c021 00004021 044000da 00004821 8ce30000 00431023 24420001 284c0000 000c100b 00406021 8cc30000 00031827 8e020000 00621021 044000ce 00407821 8e2d0000 004d1023 244d0001 29a20000 10000036 0002680b 8d020000 8cc30000 00031827 00621821 0062c02b 2442ffff 0058180a 0060c021 8e220000 00621023 24420001 284c0000 000c100b 00406021 8ca20000 00406821 8e030000 0043282b 00004021 10a000b3 00004821 2442ffff 8ce50000 00451021 0043782b 2463ffff 006f100a 10000019 00407821 00406021 8d030000 0043302b 00004021 10c000a5 00004821 2442ffff 8e260000 00461021 0043c02b 2463ffff 0078100a 0040c021 8ca30000 00031827 8e020000 00621021 04400098 00407821 8ced0000 004d1023 244d0001 29a20000 0002680b 25a20007 29a90000 01a9100a 000248c3 25e20007 29f00000 01f0100a 000280c3 000990c0 01b29023 001040c0 15300028 01e84023 01803021 030c102b 14400024 03009821 000c28c0 03252821 03a8a821 03b2a021 03a93821 8ca20000 8ca30004 afa20000 afa30004 8c820000 10400008 00a08821 92820008 92ae0010 01c27024 90e20000 01c21025 10000009 a0e20000 92ae0010 92820008 01c27024 000e7027 31ce00ff 90e20000 01c21024 a0e20000 8fa20000 8fa30004 ae220000 ae230004 24c60001 0266102b 1040ffe3 24a50008 25330001 0213102b 14400030 0270102b 01803021 030c102b 1440002b 03008821 000c28c0 03252821 03b29021 03a94821 03a8a021 03b03821 8ca20000 8ca30004 afa20000 afa30004 8c820000 1040000a 00a04021 924b0008 91220000 01621025 a1220000 928a0010 90e20000 01421025 1000000d a0e20000 924b0008 000b5827 316b00ff 91220000 01621024 a1220000 928a0010 000a5027 314a00ff 90e20000 01421024 a0e20000 8fa20000 8fa30004 ad020000 ad030004 24c60001 0226102b 1040ffdd 24a50008 0270102b 10400020 00001021 03b34021 03b08021 03004821 030c882b 000c90c0 03329021 2419ffff 16200014 01803021 02402821 8ca20000 8ca30004 afa20000 afa30004 8c820000 10400003 00a03821 10000002 a1190000 a1000000 8fa20000 8fa30004 ace20000 ace30004 24c60001 0126102b 1040ffef 24a50008 25080001 1510ffe9 00001021 7d823804 7f027a04 7da2bc04 7de2fe04 00001821 7d633804 7d437a04 7dc3bc04 00404021 00604821 01001021 01201821 8fb50034 8fb40030 8fb3002c 8fb20028 8fb10024 8fb00020 03e00008 27bd0038 End CFunction |
@matherp Just got home to see this Thanks for more code
Can't wait to try this one to see if any speed increase for what I am trying to achieve. Is there any chance you can provide the "C" code & explanation like you did for the NEC code? I really need to 'delve' into the way I drive the OLED and want to look at adding scrolling using the inbuilt SD1306 commands. Massive thanks once again . . . . WW |
Sorry, but I don't like the way pstring now performs. It is very slow (and random speed) to display a string. I am not using the cursor - am I missing something or is this how it now 'updates' the screen?
Sorry to sound negative - hopefully I have made a mistake in using it
WW |
WW Basically I need to recode the dchar routine into a cFunction, but in the meantime try replacing the s_update routine with the attached. This suppresses screen update while the pstring is taking place. S_update: cursorupdate=cursorupdate+1 if cursorenable and allowupdate and (cursorupdate mod 2) then if cursoronoff then crect(cursorx,cursory,cursorsizex,cursorsizey) cursoronoff=off else cursoronoff=on frect(cursorx,cursory,cursorsizex,cursorsizey) endif endif if allowupdate then S_refresh ireturn |
Thanks - I just tried it and although it's better, it now 'misses' some data I expect to display. Let me explain: I have a countdown counter on the OLED screen and this refreshes nicely with the pre-flashing cursor code. Then when it reaches zero I want a top line of text to flash and two bottom lines of text to remain on screen (with a bi-colour screen, the flashing text is in yellow, and the static message is in blue - this setup draws attention to the user). With the 'new' S_update code, my countdown timer misses numbers so may count down like:10,9,8,6,3,2,0 (as opposed to 10,9,8,7,6,5,4,3,2,1,0), Your original code worked fine, but the flashing text (top line) was showing signs of being 'drawn' rather than flashing. I was using pstring to display the text, then a delay, then pstring to write an empty line of text (all spaces) followed by a delay. The 'slowness' of the s_refresh caused the 'drawing' effect (rather than a rapid on/off). I will try your 'blank rectangle' method and hope this is quicker & 'neater' to the eye. My current fall-back plan is to flash the whole screen on and off (with DISPLAYON/OFF command. Thanks for your continued support - much appreciated WW |
All Please find below a new new version with all main text writing now converted to a cFunction, just use pstring(x , y, mystring$, size , orientation) to output text. Size is 1 for a standard 7x5, 2 for 14x10, etc. Orientation is 1:normal, 2:inverted, 3:rotate right, 4:rotate left. In all cases the x,y coordinates are the top left of the first character viewed from its own perspective. This character drawing code now runs 20x faster than before. The code protects against exceeding the screen display in any dimension. I've attached the basic and C as a zip because the board seems to keep corrupting things, adding spaces in basic and losing square brackets in C 2014-11-28_152850_cfunctionSPI.zip |
