Local Time 21:53 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : variable, function and sub
ajkw
Posted: 01:43am 26 Nov 2014
I came across this in some development and I am not sure if the behaviour in the first example is correct or not. I hope you can follow it but it seems a variable that is passed to a sub is not passed to a subsequent sub(function(variable)).
[Micromite 4.5D]
with the following code I get the output
10
finalout 0
'this output I feel is incorrect expected 10
finalout 1
anum = 1
test(anum)
write(anum)
End
Sub test(tt)
Print mult(tt)
write(mult(tt))
Function mult(inp)
mult = inp*10
End Function
Sub write(finalout)
Print "finalout";finalout
while with the following I get the output
10
finalout 10
finalout 1
anum = 1
test ''''(anum)
write(anum)
End
Sub test ''''(tt)
tt = anum
Print mult(tt)
write(mult(tt))
Function mult(inp)
mult = inp*10
End Function
Sub write(finalout)
Edited by ajkw 2014-11-27
Posted: 05:46am 26 Nov 2014
@ajkw
It does seem incorrect - probably treating multi(tt) as an array element in error (hence the unexpected value of zero).
However - that said, I can confirm it is correct in the latest Beta firmware that is currently under development by Geoff Graham. This may not help you immediately - BUT it has at least been identified and corrected.
I am not in a position to say when Geoff will publicly make the next version available - but as you are on the BSF, you can apply for Beta testing and Geoff should be ok with adding you to his 'team'.
Hope this is of some help . . . .
WW
Posted: 05:21pm 26 Nov 2014
Yes, there is an issue with using a function in the argument list when calling another function or subroutine - which is what your code (listed below) does:
Sub test(tt)
Print mult(tt)
write(mult(tt))
Note the text in bold.
To avoid issues like this you need to not use user defined functions in the argument list. Instead call the function separately and assign the result to a temporary variable. Then you can use the temporary variable when calling the subroutine. For example:
Sub test(tt)
Local temp
Print mult(tt)
temp = mult(tt)
write temp
The fix for this has been incorporated in the latest beta for the Micromite MkII. When the beta test period is over I plan to go back to the original Micromite code (running on the MX150) and incorporate any fixes like this.
GeoffEdited by Geoffg 2014-11-29
