Local Time 18:43 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MicroMite vs CMOS logic chips...
Posted: 06:58pm 08 Nov 2014
Hi all.
When connecting to the likes of 4000 series CMOS logic gates etc, do you need to worry about series resistors, or are the inputs to most 4000 series chips of suitably high impedance, that current limiting series resistors are not really required?
Posted: 07:21pm 08 Nov 2014
CMOS has a very high input impedance. Around 10^12 ohms and 5pF capacitance.
The only time a series resistor would do anything is if the input is driven outside the voltage limits. Then the input protection diode would come into play.
If the CMOS is fed from a different supply, the loss of one supply is the biggest risk.
Posted: 08:25pm 08 Nov 2014
Understood - thanks.
Posted: 08:35pm 08 Nov 2014
With CMOS the high impedance can be a problem with stray signals getting in.
Often, it is worthwhile putting an external resistor to ground on vulnerable inputs.
Posted: 11:13pm 08 Nov 2014
Acknowledged - thanks again.
