Forum Index : Microcontroller and PC projects : real Bug in Mk 2 vers.20
| plasma Guru Joined: 08/04/2012 Location: GermanyPosts: 437 |
beware ! Please dont try this at Home ! yes really !!! dim a(5000) sub(a) end after typing this you have no access to editor or code ! all is gone. the editor spits error invalid function name and you loose. i run into this after a typo in my led routine. first time i cant believe its true , so i flashed version 20. but its the same |
I can confirm the problem. The only way to recover is to power up with Tx and Rx shorted. [2] Sub(a)
Error: Invalid function name > list [2] Sub(a) Error: Invalid function name > new [2] Sub(a) Error: Invalid function name > micromite 4.6b20 Jim VK7JH MMedit |
I also can confirm this - same results as Jim, and needed to do the same to recover. Version 4.6 Beta 20 A nice sharp thorny bug, that one! Smoke makes things work. When the smoke gets out, it stops! |
Yes, it is. Thanks plasma, I will fix it in the next beta. Geoff Geoff Graham - http://geoffg.net |
