Forum Index : Microcontroller and PC projects : Possible BUG in MKII 4.6. B20
| atmega8 Guru Joined: 19/11/2013 Location: GermanyPosts: 738 |
Hi, possible a bug? Stripped it down to some codelines. No Output from print and reset..... print "Hello World" Do r% = CPUSpeed( 0 ) PRINT r% loop CFunction CPUSpeed 00000000 2bf81 8c45f000 8c43f000 3c02003d 24420900 7ca51400 70a23002 3c040393 48700 7c6316c0 00c41021 00621007 3c03029f 24636300 10430005 00402021 02821 00801021 03e00008 00a01821 3c0402dc 34846c00 00002821 00801021 00008 00a01821 End CFunction Following Output: > run Micromite MkII MMBasic Ver 4.6 Beta 20 Copyright 2011-2014 Geoff Graham > |
Your cfunction has the first 3 leading digits missing from each line CFunction CPUSpeed 00000000
3c02bf81 8c45f000 8c43f000 3c02003d 24420900 7ca51400 70a23002 3c040393 34848700 7c6316c0 00c41021 00621007 3c03029f 24636300 10430005 00402021 00002821 00801021 03e00008 00a01821 3c0402dc 34846c00 00002821 00801021 03e00008 00a01821 End CFunction Jim VK7JH MMedit |
Tassjim, Thank you, you directed me to The problem. IT must be an issue with The latest mmedit version. Will try to reproduce it. I copied and paste to a New programm, With this result. |
I used MMEdit to copy and paste form the PDF to MMEdit without any problems so if you can reproduce the error and give me the steps, I would be grateful. The only problems that cfunctions created was that they looked like line numbers. I think I have got rid of that problem and I hope there aren't too many people still using line numbers! Jim VK7JH MMedit |
