Local Time 18:43 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DMbasic 4.5 File Issue
akashh
Posted: 03:24pm 06 Nov 2014
I have my prototype perpaid water dispenser ready and I installed the Duinomite in it. While debugging which involves removing the sd and putting it in my PC, making file changes and putting it back, I noticed that the autorun.bas and the config file were not showing as updated on dmbasic. The microSD is 8 gb and fat32 formatted. I did this a couple of times with the same result, and I am attributing this (correct me if I am wrong) to the usage of a different FAT table perhaps? Deleting the file before saving it resulted in everything working fine.
Any ideas what could be the cause or if there is a fix for this?
Posted: 07:20pm 06 Nov 2014
This is because the firmware did not know that the card was removed and updated.
The Duinomite does not have a reliable method of detecting when the SD card is removed but I was able to incorporate a trick in MMBasic to overcome this. I forget what version this was introduced but if you upgrade to the latest version of MMBasic it should work for you.
akashh
Posted: 07:22pm 06 Nov 2014
Geoff, thanks for the reply. However, I did power off the duinomite before removing and re-inserting the SD Card. So that would not apply, right?
