Local Time 17:49 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How About This ?
hitsware
Posted: 06:03pm 31 Oct 2014
Aqui !
With the PicAxe ? What would you see on the monitor ?
donmck
Posted: 08:05pm 31 Oct 2014
  hitsware said   Aqui !
vBulletin Message
Invalid Attachment specified. If you followed a valid link, please notify the administrator
is what I get, do you have to be logged in?
Cheers Don...
https://www.dontronics.com
Posted: 09:04pm 31 Oct 2014
Same here.
hitsware
Posted: 05:46am 01 Nov 2014
Lou
Posted: 07:09am 01 Nov 2014
The output of the TxD line ??
Is this a trick question ?? Or is a punch line coming ????
I give up, what would you see ??
Lou
hitsware
Posted: 07:29am 01 Nov 2014
With a MicroMite this makes up the video part of a whole system.
But with a PicAxe ? Seems it would need the editor program ?
Posted: 08:48am 01 Nov 2014
Well it is just a serial port and the pic32 is a vt100 terminal.
So start sending some VT100 codes with the picaxe. :)
hitsware
Posted: 03:47pm 01 Nov 2014
  TZAdvantage said   Well it is just a serial port and the pic32 is a vt100 terminal.
What would you suggest whoever put that
illustration together had in mind ?
Posted: 05:51pm 01 Nov 2014
  hitsware said  What would you suggest whoever put that illustration together had in mind ?
Good grief, this is like a cryptic crossword. I "put that illustration together" and I have no idea of what you are talking about.
Posted: 06:18pm 01 Nov 2014
To use the VT100 terminal as a VGA or composite display device for the PICAXE or any other micro-controller by way of a serial port.
ANY micro-controller can talk to the VT100 unit, not just the Micromite, if that is what you were perhaps thinking.
And no - you CANNOT use the VT100 unit to edit or program the PICAXE. You must use the free Programming Editor or AXEpad software for that. The reason for this, is that the MicroMite has the editor "Built-in" to it's firmware, whereas the PICAXE does not have any kind of editor on-chip, which is why you have to use the programmer for those chips.
Having said that, you can program the PICAXE to send the expected VT100 codes at the correct baud-rate and you will get the same output on the screen - this is EXACTLY how I produced the static message screen in the other thread about my loving the big text modes on the VT100. I was using a PICAXE to send the codes to the VT100.
