Forum Index : Microcontroller and PC projects : General purpose 8 port I/O chip
I have come across this new chip which could be quiet useful: http://www.analog.com/static/imported-files/data_sheets/AD55 93R.pdf It is an eight port I/O chip with an I2C interface. What is outstanding is that any pin can be independently configured as an: - Analog output (ie, DAC) - Analog input (ie, ADC) - Digital input (with optional pulldown) - Digital output (normal or open collector) The DAC and ADC are 12 bit and it includes a 0.5% accurate voltage reference. It makes a great general purpose I/O chip. I have asked for some samples - now to think up an interesting application... Geoff Geoff Graham - http://geoffg.net |
How much? Smoke makes things work. When the smoke gets out, it stops! |
| JohnL Senior Member Joined: 10/01/2014 Location: SeychellesPosts: 128 |
More than US$7each for qty 10 from Digkey. No thanks. If speed is not an issue, better option is to configure a ucontroller as universal I/O device. Many low end ucontrollers don't have DACs. |
I have successfully used a 2nd(or 3rd!) MicoMite IC on I2C to act as port expansion. My model elevator project uses three MM chips. One is a CPU(the master), one is an input controller(slave #1), and the third one is an output controller(slave #2). A triple-core MicroMite.
There was also a MCP serial port-expansion chip that talked on I2C - I forget the part number. Smoke makes things work. When the smoke gets out, it stops! |
| Zonker Guru Joined: 18/08/2012 Location: United StatesPosts: 772 |
Wow..! Great find Geoff.. In one chip, you could design several different kinds of interface boards with 12bit analog and digital control... awesome I can think of a few uses right off... Will have a read of this one... Thanks.! |
12 bit DAC and ADC in one package is very useful. Jim VK7JH MMedit |
jman![]() Guru Joined: 12/06/2011 Location: New ZealandPosts: 711 |
Geoff That's a great I2C device I have ordered some samples I post the results here when they arrive Jman |
