Local Time 17:49 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : small (amusing) bug
Posted: 09:16am 23 Oct 2014
has anyone noticed this before:
> 9 edit
Micromite MMBasic Ver 4.6 Beta 1
Copyright 2011-2014 Geoff Graham
at the command prompt, typing a "line number" followed by certain commands causes a reboot. i've tried '9 edit' and '9 cpu'. '9 memory' doesn't reboot and does the same as 'memory'.
tested with 4.5C and 4.6 Beta 1
rob :-) Edited by robert.rozee 2014-10-24
hitsware
Posted: 10:15am 23 Oct 2014
Is it a reboot or the same as VERSION ?
G8JCF
Posted: 03:25pm 23 Oct 2014
@RR
Thank you ! I've been looking for a way of causing a MMBasic reset in software and looks like you have found the way, although not quite as good as the h/w method.
@Geoff
could we please have an official way of causing a complete reset of MMBasic via the CLI, ie erase program, and all OPTION settings, eg CTRL+C, RESET CRLF ?
I'm asking for this capability because as part of my PIC32 programmer, I need to reset the uMite.
BTW, this is a very, very, very low priority request, there are far more important things to get done first.
Many thanks
Peter
The only Konstant is Change
Posted: 03:58pm 23 Oct 2014
the command "WATCHDOG 5" in your code (or at the command line) nicely does a reset, i've been using it to check that the startup message displays correctly with newly created micromites for quite a while.
rob :-)
G8JCF
Posted: 03:27am 24 Oct 2014
@rr
Thanks for that tip, I'll file it away for future use.
Peter
f1fco
Posted: 12:03am 26 Oct 2014
hello to all,
is it a 4.6 version available ?
where to download it ?
thank you for answer
Pierre, from France
73s de F1FCO
Posted: 01:59am 26 Oct 2014
Give me a couple of days. I plan to release a beta version of it soon.
EDIT and it will also fix this bug (a good find BTW Rob).Edited by Geoffg 2014-10-27
twofingers
Posted: 02:29am 26 Oct 2014
@Pierre
plz take a look at this thread.
Michael
