Local Time 17:49 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pic32mx170 programming
plasma
Posted: 01:22pm 22 Oct 2014
i found no pic32mx170 in the list from mplap ipe.
i read some about the mplapx ipe but cant find a link or todo.
can anyone help here ?
thx
Zonker
Posted: 02:11pm 22 Oct 2014
Humm.. The version I have (v2.05) has both the PICMX170F256B and D versions...
I did notice the little LED thing on the software stayed RED but the 170's programed OK...
G8JCF
Posted: 02:14pm 22 Oct 2014
If you have a working 150F with 4.5 MMBasic you could try http://www.g8jcf.dyndns.org/mmbasic/MMProg32RPC.html to program your '170F.
Peter
The only Konstant is Change
plasma
Posted: 03:12pm 22 Oct 2014
thx a lot
Posted: 07:42pm 22 Oct 2014
If you're stuck for a way to program a PIC32 you can always resort to using either a Raspberry Pi or a FT232 board using the code I posted towards the end of this thread - work backwards
Frank N. Furter
Posted: 07:22pm 23 Oct 2014
Hi Plasma,
did you have a PICKIT3?
I downloaded yesterday the MPLAB X IDE v2.20 and programmed my 32MX170 successfull with the MPLAB IPE v2.20 and my PICKIT3...
Frank
Posted: 08:04pm 23 Oct 2014
  Frank N. Furter said   Hi Plasma,
Frank
i have the version 2.05 of the IPE here, and although it does work, it will not fit on the display of my computer - a little netbook with a 1024 x 600 screen. vital parts of the interface are invisible off the bottom of the screen, making it an absolute pain to try and navigate.
is the 2.20 version any better? is it available separately from MPLAB X? how big is the download?
i've just ordered a (clone) pickit 2 specifically to use with pic32prog. deliberately didn't get a pickit 3 as i wanted to have a closer look at the hardware in the 2.
rob :-)Edited by robert.rozee 2014-10-25
plasma
Posted: 08:24pm 23 Oct 2014
Hi Robert ,
the download has 369 mb from Microchip / download Folder but the windowssize from the new Ipe
will also not fit in your resolution.
@ Frank : i have a pickit 3 and now the 2.2 version from Mplab x.
i hope i can create a plugin for my Ledstripe .
Frank N. Furter
Posted: 09:38pm 23 Oct 2014
@Rob:
I worked always with the "normal" MPLAB and don't know the differences to older MPLAB X versions...
It seems that you must install the complete package (369mb installer file as Plasma wrote)!
@Plasma:
I hope too that your plugin works!
Let me know If you have problems with flashing your PIC. I had first problems with my implemented ICSP circuit.
Frank
vegipete
Posted: 11:59am 24 Oct 2014
@Robert
you could try moving the window with the keyboard:
Press ALT-SPACE, then 'M'
Now the arrow keys should shift the screen around.
Press 'Enter' when done shifting.
Posted: 01:57pm 24 Oct 2014
  vegipete said   @Robert
tried that. alas, when you hit enter the window snaps back to having a sliver of the title bar at the top of the screen and the rest invisible off the bottom. i'm running XP.
the only thing i have found that (kindof) works is figuring out where the control i want is, then blindly tabbing to it and hitting 'enter'. it is a fairly hit-and-miss process.
rob :-)Edited by robert.rozee 2014-10-26
