Local Time 16:57 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PIC32MX150 or PIC32MX170
Frank N. Furter
Posted: 07:31pm 20 Oct 2014
Hi all,
what is the way in the future? Is the PIC32MX150 supported in the future or is it better to use the PIC32MX170 for a further project? (...I don't need the additional features and the additional RAM for my next Project...)
Frank
Posted: 08:14pm 20 Oct 2014
As I understand things, you can still use either one, although, Geoff will be concentrating his firmware updates for the 170 series chips.
So, if you have a stock of 150's, you can still use these, but I would expect that the new default chip is the 170 series.
Posted: 02:08am 21 Oct 2014
Frank,
Geoff has 'hinted' that the firmware will stop at v4.5x for the 150.
He is working very hard on new features that will only be for the 170.
So given a choice - always opt for the 170 for new 'developments'.
IF your project currently runs 100% ok on v4.5D then you can definitely use any 'remaining' 150's that you may have lying around.
Does this info help??
WW
Frank N. Furter
Posted: 02:40am 21 Oct 2014
Hi WW,
thank you for this info!
No, my project doesn't work really ok with v4.5D - I need the I2C-Slave function and this does not work properly.
I think I must switch to the 170
...they are not available over Farnell - only the 150 is available without any difficulty...
Frank
Posted: 03:01am 21 Oct 2014
I do have 28-pin DIPs (50MHz), and the 44-pin TQFPs (both 40MHz and 50MHz).
However, if you are after 28-pin SMD 170s then I don't have any currently.
The most consistent supplier in terms of availability seems to be DigiKey (and trust me, I keep my eye on global supply on a daily basis).
So MX170 is the way forward until Geoff brings out the MX190 version
