Local Time 16:56 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RTC Problem
edu001
Posted: 03:29am 20 Oct 2014
Hi
I have an odd problem with the PCF8563 RTC on the MicroMite, when I run the test code below which is a simple loop the CPU will only SLEEP on every other cycle ie:
SLEEP miss SLEEP miss SLEEP miss etc
The full code is far more complex but has exactly the same problem, I have tried various pauses FOR NEXT loops DO loops without success
Any ideas ?
Interval = 5 ' sets sleep time (integer value between 1 and 59 inclusive)
Pause 500: ?:? "Entering Loop":?:Pause 500
DO
StartInt
? "SLEEPING"
CPU SLEEP
? "AWAKE:"
LOOP
' ------------------------ SUBROUTINE -----------------------------------------------
SUB StartInt
I2C OPEN 100,100 ' open an i2c connection with bus speed 100KHz and 100mS timeout
I2C WRITE &H51, 0, 2, &H0F, Interval+1 ' pass Interval time to RTC timer register
I2C WRITE &H51, 0, 2, &H0E, &B10000010 ' Set Minutes OR Seconds: MINUTES=&B10000011 SECONDS=&B10000010
I2C WRITE &H51, 0, 2, &H01, &B00000001 ' reset any triggered flags and start the timer countdown
I2C CLOSE ' close 12c connection
END SUB
atmega8
Posted: 03:44am 20 Oct 2014
what stops the sleeping mode?
edu001
Posted: 03:54am 20 Oct 2014
  atmega8 said   what stops the sleeping mode?
Interval is set to 20 secs when time expires INT pin changes state - active LOW (connected to MicroMite WAKEUP pin)
Sorry 5 secs in the test codeEdited by edu001 2014-10-21
Posted: 06:51am 20 Oct 2014
I think what you need to do is add a bit of a delay between the RTC waking the MicroMite and before you put it back to sleep.
You may find the Int pin still 'active'. After the line 'Print "AWAKE:" add Pause 500
See how that goes - you may need to 'experiment with the value of the Pause (increase and/or decrease until it works.
Let us know how you get on . . .
edit: The more I think about it, the more I am convinced this is the issue - simple test will prove me wrong (or right )Edited by WhiteWizzard 2014-10-21
edu001
Posted: 07:16am 20 Oct 2014
  WhiteWizzard said   I think what you need to do is add a bit of a delay between the RTC waking the MicroMite and before you put it back to sleep.
I have tried delays everywhere upto 5 secs I get the same thing, I have also tried using I2C Write to stop and start the clock (control/status 1 register)
atmega8
Posted: 07:25am 20 Oct 2014
What wakes him up?
He cannot wakeup himself without external help!
edu001
Posted: 07:28am 20 Oct 2014
  atmega8 said   What wakes him up?
Wakes which one up ?
edu001
Posted: 07:30am 20 Oct 2014
Ok here s another observation it always ignores the first cycle, I tried to programme a single sleep mode but it cycles twice before it sleeps
edu001
Posted: 07:31am 20 Oct 2014
RTC or CPU ?
atmega8
Posted: 07:40am 20 Oct 2014
The micromite..
Will the rtc trigger pin 16?
If so, you have external help;-)
edu001
Posted: 07:48am 20 Oct 2014
  atmega8 said   The micromite..
The RTC triggers PIN 43 (44 pin micromite) it all works, its a cycling issue, it does not sleep on every cycle
atmega8
Posted: 08:38am 20 Oct 2014
Your hardware setup is ok?
Pullups/downs...
Power supply ok?
Test another..
BobD
Posted: 08:51am 20 Oct 2014
The Wakeup input on the uMite is edge triggered in either direction.
What is the RTC INT pulse like?
Is it remaining low when triggered or is it a 16 millisecond pulse?
Have you actually measured that pin?
Posted: 08:55am 20 Oct 2014
I have recommended that edu001 monitors the RTC Int pin (active low) and waits for it to be at a high level before the SLEEP command is issued.
He is testing this now and carrying out other measurements.
With his findings we can then make our next batch of 'suggestions'
edu001
Posted: 09:31am 20 Oct 2014
  atmega8 said   Your hardware setup is ok?
Pullups/downs...
Power supply ok?
Test another..
Yes pullups are all ok the power supply is a very clean 3.31v
edu001
Posted: 09:33am 20 Oct 2014
Here is the output from the logic analyser
http://imgur.com/iCixP7L
Posted: 09:39am 20 Oct 2014
Can you do the test where you pulse a pin immediately before SLEEP and pulse the same pin immediately after SLEEP.
This then allows us to see where the program is at (in relation to the rising edge of the INT pin.
If you can post a zoomed in image so we can see timings and I2C detail then it could help resolve
edu001
Posted: 09:59am 20 Oct 2014
More info 3 images
http://imgur.com/fEaCaPm,zE9DGvA,xns6D4R
edu001
Posted: 10:08am 20 Oct 2014
  edu001 said   More info 3 images
Missed one http://i.imgur.com/JPZuGMM.png
Posted: 10:18am 20 Oct 2014
Brilliant.
Now can you sample 4 cycles (reduce the sleep time to something like 2 seconds) i.e. grab about 10seconds of sample and send the screen shot.
I don't need to see the I2C detail, but as long as I can see the INT pin level and the 'test' pin levels and their relative timings then that would be helpful (Leave I2C connected - will just be 'blips' in the screen grab).
Thanks Jed . . . .
