Local Time 16:01 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : how to attach switch ?
atmega8
Posted: 12:46am 12 Oct 2014
Hi, simple , hope not to stupid, question.
Pin 7 is connected via a 10K Resistor to VCC.
The Switch pulls it down to low.
Is this the best way to avoid bounces?
I get lots of them ;-((
How can i debounce in Software?
Codesample?
setpin 7, intl, keypress
keypress:
print "keypress"
count = count +1
print count
ireturn
atmega8
Posted: 12:52am 12 Oct 2014
Ok,
did it this way:
keypress:
pause 20
if pin(7) = 0 then
count = count +1
print count
print "keypress"
endif
ireturn
atmega8
Posted: 01:00am 12 Oct 2014
Again,
using a pause in an Interrupt causes some headache to me.
But as Geoff explained in another Thread:
"The pause command constantly checks for an interrupt condition and if one has occurred it will execute the interrupt routine. On return from the interrupt the pause commend will continue with the pause but any time spent in the interrupt routine will be subtracted from the pause time so that the pause would be the same with or without the interrupt.
You can also use pause in an interrupt routine although that cannot be interrupted because you are already in an interrupt."
...the pause within the Interrupt Service Routine will miss other Interrupts.
As i remember this Interrupt is completely lost?!
So you have to decide if this will be a Problem in your code...
atmega8
Posted: 01:03am 12 Oct 2014
@ Geoff,
seems that you have not implemented to use the PIC-internal pullups.
In my case this will save me a resistor;-)
Will you implement it in a next release?
THXEdited by atmega8 2014-10-13
Posted: 01:19am 12 Oct 2014
If you want to eliminate bounce, add a capacitor.
So a resistor from Vcc to one side of the switch and a capacitor from that same side to GND.
Then the other side of the switch to GND.
When the switch is pressed this will cause the capacitor to dump its charge to gnd giving you and active low. it stays low until the switch is released AND the capacitor is charged via the resistor. This will effectively giving you a delay on the logic level of the pin that is used for the switch. A debounce!
No need to fix it in software. You can but it gets more tricky. My personal thinking is that if it is easy and cheap to solve in hardware do that. Unless of course there are strict cost or space restrictions.
It is important to spend as little time in a interrupt routine as possible.
Also look at the SUB/END SUB structure to replace using labels and the use of ireturn.
Consider the use of a label and iReturn as deprecated.
Edited by TZAdvantage 2014-10-13
Posted: 01:35am 12 Oct 2014
  atmega8 said   @ Geoff,
THX
Yes, that will be in the next version (including pull downs).
atmega8
Posted: 02:51am 12 Oct 2014
THX
Thank you Geoff,
looking forward to the next Version, hope it will be soon ;-)
atmega8
Posted: 03:26am 12 Oct 2014
if i use end Sub or Exit Sub on a settick Interrupt i get this error:
[43] Exit Sub
Error: Nothing to return to
Can you help me with tis ?
atmega8
Posted: 03:32am 12 Oct 2014
OK, sorry....
changed Label (Label:) to Sub (SUB Label)
So it works !
Posted: 12:05pm 12 Oct 2014
Interesting article about debouncing switches. The circuit in fig 3 seams to be pretty good, and only 3 extra components. Also goes into software solutions ( in C )
Its a 333k pdf. http://www.eng.utah.edu/~cs5780/debouncing.pdf
Posted: 12:30pm 12 Oct 2014
I always put a 1k in series with the IO pin - copied from the PICAXE method.
It limits current into or out of the IO pin, and has become my default wiring for all switches and button inputs, including relay contacts etc.
Not sure if this is strictly needed with the uM, but I do it anyway, as that is what I was used to with PICAXE, and the theory is still good, even though I am on another device.
paceman
Posted: 05:04pm 12 Oct 2014
  Gizmo said   Interesting article about debouncing switches. The circuit in fig 3 seams to be pretty good, and only 3 extra components. Also goes into software solutions ( in C )Glenn
Interesting article Glenn. Just checked the price of those MC14490 chips (with six de-bounce circuits). Element14 still want $10 each for them which probably makes them unrealistic, but e-Bay has them for closer to $2 if you can trust the quality.
Greg
