Local Time 16:57 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Classic Basic: Kaleidoscope
Oldbitcollector
Posted: 05:54pm 08 Oct 2014
Here's a little old school Kaleidoscope I converted for use on the Micromite. This version is friendly with standard VT100 terminals. Tested with Putty.
[code]
1000 Rem KALEIDOSCOPE
1010 Rem PATRICK LEABO--TUSCON
1020 Rem 3-14-82
1030 Rem Converted to Micromite Companion 9-29-14 by Jeff Ledger
1040 Dim MT(33)
1045 Randomize Val(Right$(Time$,2))
1046 Dim Ch$(10) : Dim dy(8) : Dim dx(8) : Dim nt(8)
1050 CH$(1)="":CH$(2)="":CH$(3)="":CH$(4)=""
1060 WIDE = 80
1065 color 7,0
1066 cls
1070 Rem START
1075 locate 0,0
1080 A= 31:B= 15:X1= 16:Y1= 8
1090 A= Int(Rnd(1)*20+19):B=Int(Rnd(1)*10+13)
1100 Restore
1110 For N= 0 To 7:Read DX(N):Read DY(N):Next
1120 Data 1,0,1,1,0,1,-1,1,-1,0,-1,-1,0,-1,1,-1
1130 For N= 0 To 7:Read NT(N)
1140 Next
1150 Data 1,3,5,6,8,10,12,13
1160 For N= 0 To 24:MT(N)=N+1:Next
1170 For C= 0 To 12:Next:CLS
1180 For NN= 1 To 50
1189 Rem DRAW LOOP
1190 DI=Int(8*Rnd(1))
1200 If Rnd(1) < .25 Then CH$=CH$(4*Rnd(1)+1):GoSub 1600
1205 If Rnd(1) < .25 Then CC=CC+1:If CC>7 Then CC=0 Else COLOR CC,0
1210 GoSub 1590
1220 For N= 1 To Int(Rnd(1)*8)
1230 X1= X1+ DX(DI):Y1= Y1+ DY(DI)
1240 If X1< 1 Then X1= A:GoTo 1260
1250 If X1> A Then X1= 1
1260 If Y1< 1 Then Y1= B:GoTo 1280
1270 If Y1> B Then Y1= 1
1280 X2= 40- X1:Y2= 24- Y1
1282 ch$=Chr$(219)
1290 aa=Int(Rnd*6)
1291 If aa = 5 Then color=Int(Rnd*7)
1293 color color,0
1295 LOCATE Y1,X1:Print CH$;:If WIDE = 80 Then LOCATE Y1,X1+40:Print CH$
1300 LOCATE Y1,X2:Print CH$;:If WIDE = 80 Then LOCATE Y1,X2+40:Print CH$
1310 LOCATE Y2,X1:Print CH$;:If WIDE = 80 Then LOCATE Y2,X1+40:Print CH$
1320 LOCATE Y2,X2:Print CH$;:If WIDE = 80 Then LOCATE Y2,X2+40:Print CH$
1330 Print Chr$(27)+"[f"
1340 Next :Next
1350 GoTo 1070
1360 Rem VECTORS
1370 For CC= 0 To 12:GoSub 1720:Next
1380 CC= INT (63* Rnd (1))
1390 If Rnd (1)= .5 Then CC= 1
1400 If Rnd (1)> .5 Then CC= CCAND 15
1410 MA= CCAND 56
1420 PLOT 6,CC,12:CC= CCAND 15
1430 If CC> 12 Then CC= 12
1440 GoSub 1790
1450 A= INT (Rnd (1)* 50+ 60):B= INT (Rnd (1)* 50+ 60):GoSub 1580
1460 For N= 1 To 50
1470 X1= X3:X2= X4:Y1= Y3:Y2= Y4:GoSub 1580
1480 DI= INT ((X3/ A)* 8):GoSub 1790
1490 PLOT 2,253,X1,Y1,242,X3,Y3,255
1500 PLOT 2,253,X1,Y2,242,X3,Y4,255
1510 PLOT 2,253,X2,Y1,242,X4,Y3,255
1520 PLOT 2,253,X2,Y2,242,X4,Y4,255
1530 If Rnd (1)< .25 Then CC= INT (8* Rnd (1)):GoSub 1720:PLOT 6,CCOR MA
1540 If Rnd (1)< .1 Then PLOT 31
1550 Next
1560 For CC= 0 To 12:GoSub 1720:Next
1570 CC= INT (63* Rnd (1)):GoTo 1070
1580 X3= INT (A* Rnd (1)):Y3= INT (B* Rnd (1)):X4= 127- X3:Y4= 127- Y3:Return
1590 Rem
1600 OK= OK+ 1:If OK> 2 Then OK= 0
1610 On OK GoTo 1660,1690
1620 NS= 4:GoSub 1710
1630 NS= 0:GoSub 1710:NS= 2:GoSub 1710
1640 NS= 4:GoSub 1710:NS= 7:GoSub 1710
1650 Return
1660 NS= 1:GoSub 1710:NS= 3:GoSub 1710
1670 NS= 4:GoSub 1710:NS= 6:GoSub 1710
1680 Return
1690 NS= 0:GoSub 1710:NS= 3:GoSub 1710
1700 NS= 5:GoSub 1710:NS= 7:GoSub 1710:Return
1710 Return
Sub CLS
Print Chr$(27)+"[f";:Print Chr$(27)+"[2J";
Sub COLOR foreg,backg
'Convert GWBASIC COLOR Commands To reasonable VT100 colors.
If foreg < 8 Then foreg = foreg +30
If foreg > 8 And foreg < 15 Then foreg = foreg +22
If backg < 8 Then backg=backg+40
If yy > 8 And backg < 15 Then backg=backg+32
Print Chr$(27)+"[0;"+Str$(foreg)+";"+Str$(backg)+";1m";
Sub LOCATE XX,YY
Print Chr$(27)+"["+Str$(XX)+";"+Str$(YY)+"f";
Pause 7
Sub Display
For x = 14 To 255
Print x;" "+Chr$(x)+" ";
Next x
End
[/code]
My Propeller/Micromite mini-computer project.
Posted: 08:53pm 08 Oct 2014
While it does run, I am a little bit confused about some of the code.
Lines 1620 to 1710
There is a variable NS that gets assigned a value then a gosub 1710
Line 1710 is a return so the sub does nothing.
You use CH$ as a variable as well as an array.
While this does work, it is a risky habit.
If you were to change the COLOR sub (and variable) to different names, it would be relatively easy to adapt the program to run on Maximites as well as micromites.
The same applies to the LOCATE sub.
Posted: 10:54pm 08 Oct 2014
  TassyJim said   While it does run, I am a little bit confused about some of the code.
Lines 1620 to 1710
Agreed - I don't get that code either.
...but then, that would not be a first for me...
Oldbitcollector
Posted: 06:26am 09 Oct 2014
I won't take credit for the original code.. :)
But I will take credit for my hacking of it. :)
