Local Time 15:00 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Saving program/transferring to new chip
Lee3
Posted: 12:57am 05 Oct 2014
Is there a way to transfer a text file into a micromite in edit mode - ie transfer a program in??
I can do a LIST ALL command then export the output in my terminal emulator, thus saving a text file of the program, but when I try and send the text file to another chip using the emulator, I just get a small load of gibberish go across...
Posted: 02:45am 05 Oct 2014
RTFM.
Page 48 XMODEM command.
http://geoffg.net/Downloads/Micromite/Micromite%20Manual.pdf
Lee3
Posted: 02:57am 05 Oct 2014
Not only have I read the thing, I've printed AND bound it....
G8JCF
Posted: 03:49am 05 Oct 2014
Lee
Have you tried using MMEdit ?
Or am I missing the point of your question ?
Peter
The only Konstant is Change
Posted: 03:53am 05 Oct 2014
There is also the AUTOSAVE command.
cosmic frog
Posted: 05:39am 05 Oct 2014
I also struggled with this but found using the xmodem command worked great.
Dave.
Lee3
Posted: 10:56am 05 Oct 2014
I'm using OSX, so can't use MMEdit...
Posted: 01:50pm 05 Oct 2014
Are you able to add a delay between lines in you terminal program?
Most terminal programs have an option to set a character delay and hopefully a line delay.
Start with a line delay of 300mS and if successful, start reducing the delay.
The micromite does need time to process each line as it is entered.
"Slow and steady wins the race"
MMEdit runs on Linux under Wine and I think it runs under the OSX equivalent.
I found the serial port interface of Wine to be a pain which is why I added TCPIP to the MMEdit connection options.
With Linux, I have had good results using a serial to TCPIP program - ser2net.
You then set MMEdit or TeraTerm to TCPIP localhost (127.0.0.1) and the port you have setup.
