Local Time 15:57 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite pin 1 resistor
Lee3
Posted: 12:54pm 27 Sep 2014
Hi there
I've read in Silicon Chip and on here that pin 1 can be connected to Vcc directly, or via a 10k resistor. Does it matter? Is there any particular reasons why I should use a resistor??
I'm prototyping a small project, will be handy to leave pins 1 and 28 shorted with the stripboard trace under the chip if I don't need to use a resistor.... :)
Lee
Posted: 01:07pm 27 Sep 2014
Microchip recommend that you use a resistor. It could be because you can then program the chip in circuit or it might be to limit the effect spikes on the power rail.
I often connect pin 1 direct to 3.3V with no problems at all.
hitsware
Posted: 01:21pm 27 Sep 2014
If you use a resistor, you can short it to ground for a reset.
