hitsware Guru Joined: 23/11/2012 Location: United StatesPosts: 535
Posted: 03:15pm 21 Sep 2014
OR
Can a MicroMite chip be programmed as a ColorMax ?
Grogster Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10075
Posted: 03:25pm 21 Sep 2014
Not that I am aware of.
The uM chip is not fast enough, nor does it have enough memory to be able to squirt out colour either in composite or VGA.
From my understanding, on the MaxiMite, the VGA or composite is clocked out of the chip from the raw C code in the background - it is not something you can do from within the MMBASIC language.
However - why don't you get yourself one of the cool MicroMite Companion kits like I have just got? A uM driving a powerful graphics controller - should suit you down to the ground. Smoke makes things work. When the smoke gets out, it stops!
Posted: 04:47pm 21 Sep 2014
Not me ( as I understand myself )
My whole interest is audio out ..
Maybe ' SID ' but ?
The Propeller is an enhanced VT100
( right ? ( in this case ? ) )Edited by hitsware 2014-09-23
Posted: 09:01pm 21 Sep 2014
Does the sound have to come from the MicroMite, or are you interested in all sound modules you could add to the MicroMite, for example?Smoke makes things work. When the smoke gets out, it stops!
