Local Time 13:24 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : HX711
jman
Posted: 09:19am 17 Sep 2014
Hi all
I have been looking at an HX711 24bit AtoD for load cells
the data sheet has a timing chart that suggests the SCK
pin should be toggled at 50us or less I have some crude code for the Micromite but I don't think the Micromite is quick enough.
Is this something that can be done with the new plugin feature ?
My C is well C...p so any assistance will be greatly appreciated
2014-09-17_191645_hx711.pdf
Dim Weight(25)
PD_SCK = 3
DT = 4
SetPin Dout, DIN
SetPin PD_SCK, DOUT
Main:
Pin(PD_SCK) = 0
Do While Pin(DT) = 1
For I = 0 To 24
Pin(PD_SCK) = 1
Pin(PD_SCK) = 0
Weight(I) = Pin(DT)
Next I
For I = 0 To 24
Print Weight(I)
Next I
Jman
Posted: 09:36am 17 Sep 2014
Could you not use SPI for that?
aargee
Posted: 07:30pm 17 Sep 2014
The problem is that SPI only handles 8 or 16 bits at a time, whereas JMan needs 24 bits.
I'm wanting to play with Neopixels and have the same issue, they use timing and 24 bits.
The Plugin feature is the way to go but my C is not the best either.
- Rob.
