Local Time 04:38 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 4 $ WiFi Serial Transceiver Module
     Page 1 of 7
atmega8
Posted: 12:07am 11 Sep 2014
WOW !!!!!
This opens a new world of communication also for Micromite and other Conrollers.
•Integrated RF switch, balun, 24dBm PA, DCXO, and PMU
•Integrated RISC processor, on-chip memory and external memory interfaces
•Integrated MAC/baseband processors
•Quality of Service management
•I2S interface for high fidelity audio applications
•On-chip low-dropout linear regulators for all internal supplies
•Proprietary spurious-free clock generation architecture
•Integrated WEP, TKIP, AES, and WAPI engines
http://espressif.com/en/products/esp8266/
http://olimex.wordpress.com/2014/09/08/esp8266-wifi-chips-an d-modules-arrived/Edited by atmega8 2014-09-12
Posted: 12:34am 11 Sep 2014
Got one of those, not get it to work yet.....
Here are some more links:
http://hackaday.io/project/2879-ESP8266-WiFi-Module-Library
http://www.esp8266.com/viewtopic.php?f=8&t=6
http://www.mikrocontroller.net/topic/342240
Can be controlled through serial, SPI and SDIO.
atmega8
Posted: 04:39am 11 Sep 2014
  TZAdvantage said   Got one of those, not get it to work yet.....
exactly the modules i talked about.
trivial to get them up and running.
Where is your Problem ?
Posted: 05:34am 11 Sep 2014
I tried the example that is on esp8266.com but it does not see my wifi router.
I think i need to give it its own power supply, the power ont he arduino uno i tried it on might not give enough.
Do you have some working code?
atmega8
Posted: 05:51am 11 Sep 2014
  TZAdvantage said   I tried the example that is on esp8266.com but it does not see my wifi router.
My "Working Code" is that the AT Commandos are working like a charme and that is what i need, enough for home automation !
Be carefull, they only accept 3,3 Volt, 5 Volt will kill them...
atmega8
Posted: 05:53am 11 Sep 2014
When they are "unconfigured" the modules consume nearly 200mA.
When you configure them, the current will sink to 40-60mA...
Posted: 06:21am 11 Sep 2014
These are $4 units so expect well above average current draw (typical syndrome from cheap 'fakes' as my 'followers' will know!).
As has been said many times before - these are great for personal use; but don't expect consistent reliability, or performance matching the 'official' datasheet, or any guarantee for when it fails.
These cheap units are great for proof-of-concept; and also for personal use and that about all. So grab a bargain, and be prepared to waste time getting it working in the same way as then next person!
Warning over . . . . .
atmega8
Posted: 06:59am 11 Sep 2014
  WhiteWizzard said   These are $4 units so expect well above average current draw (typical syndrome from cheap 'fakes' as my 'followers' will know!).
the chip ESP8266 seems to be not older then 1-2 months.
Maybe you are wrong ?!
Posted: 07:16am 11 Sep 2014
This says it all . . . .
[quote]Everyone (including the great [Sprite_TM]) has currently hit a roadblock . . . we’ll have to wait until someone from Tensilica, the company behind the guts of this chip, to chime in and help everyone figure out how this thing actually works.[/quote]
New does not automatically mean 'good'. I am all for creativity but also think that quality is important. Lets see how it goes . . . . .
edit: As always, I am prepared to be proven wrong
Edited by WhiteWizzard 2014-09-12
Posted: 12:02pm 11 Sep 2014
Cheapest is not necessarily the best.
Still - impressive little modules for the price, but if you have to fight them to make them work, you would probably lose less hair with a more expensive module.
Just about everyone has their own opinion on RF data modules, so I will just offer my own 2c here:
I use the Radiometrix range of modules. These are NOT known for being cheap(actually they are quite expensive), but they are very well documented, compliance tested and supported. I have used a couple of hundred Radiometrix transmitter modules over the years, and have not had a single failure in any of them yet.
I do distinctly remember bench testing some of those cheap-as-chips RF modules years ago, and gave up, cos I could not make the bloody things work right. In the end, I bought a couple of the Radiometrix modules - just to test, knowing full well they were about ten times the price of the cheap ones, but guess what? They worked from the very first bench test, exactly as expected, no hair loss for me, and they then became the product's transmitter.
Something else to consider - regulations. The Radiometrix stuff(along with many other quality modules, by the way), have full type-approval - they have been tested in a lab for harmonics and spurious emissions, correct power output levels etc. Cheap modules will not be tested like that, and could possibly be emitting all over the band when they are enabled - you would never know unless you were to put one on a spectrum analyser.
I have to side with WW here. Cheap modules are OK for hobby use and tinkering around(assuming you can get them to co-operate!), but as he says - don't use in a product.
plasma
Posted: 03:24am 12 Sep 2014
I ordered 4 cheap modules from ebay .
I need to build a network with .
If i got it to work i'll show my success here.
Btw.: i have 2 wifly network module also
But booth have a buffer oberflow if i send
Much datas on maximal speed.
Also the ping times (ad hoc modus, with only 2 devices)
Are horrible floating from 5 ms up to 120.
And the wifly modules Is really expensive.
After Microchip gets Roving Network there are
no software updates anymoore.
So i try my luck with the cheapy chinese boards.
atmega8
Posted: 06:25am 12 Sep 2014
http://youtu.be/WFo4Fs0p_NY
viscomjim
Posted: 05:05am 15 Sep 2014
Ran across this article. Seems doable. I'm going to research a bit more.
Serial to WiFi
plasma
Posted: 08:11am 15 Sep 2014
i have 2 of thes Hilink module from above , booth working
Oldbitcollector
Posted: 04:21pm 22 Sep 2014
So I started playing with one of these tonight connected to my MMC board. This power hungry little sucker made my 5v regulator start to sweat a bit, bit it held in there for the hour I was playing with it. :)
I'm using a little terminal program we wrote a few weeks ago for the Micromite;
[code]
Open "Com1:115200" As #1 'Connected the unit to Micromite Com1
terminal:
a$=""
b$=""
a$=Inkey$
If a$ <> "" then Print #1,a$;
If Loc(#1) >=1 then b$=Input$(1,#1)
char=asc(b$)
If char > 31 then Print b$;
If char = 13 then Print " "
Goto Terminal
[/code]
Here's a little "cheat-sheet" that may help you with the commands. I was able to connect the unit to my wireless network, turn on the server, and then establish a telnet connection between my linux box and the terminal.
[code]
AT+RST Reset
AT+CWMODE=3 Set as Client and Access Point
AT+LAP List Access Points
AT+JAP="ssid","password" Join Access Point
AT+CIFSR Display Current Assigned IP Address
(Unit it PINGable at this point)
AT+CIPMUX=1 Set Single Connection
AT+CIPSERVER=1,{port} Open Socket Server
(A telnet connection can be opened at the specified port)
AT+CIPSEND=0,{number of bytes} > Send number of bytes
[/code]
There will probably be a few of us playing with these using the Micromite, so bookmark this thread as well.
http://propellerpowered.com/forum/index.php?topic=688.0
Jeff
My Propeller/Micromite mini-computer project.
viscomjim
Posted: 12:16am 23 Sep 2014
Hi OBT,
Thanks for a quick start on this. I will be following your propeller thread to see what you guys accomplish with this unit. Would be great to get the uMite "online" and maybe able to control things over the internet. Looking forward to progress.
Oldbitcollector
Posted: 12:12pm 23 Sep 2014
Just got a simple webserver running on my Micromite. :)
http://propellerpowered.com/forum/index.php?topic=688.msg463 3#new
viscomjim
Posted: 01:02pm 23 Sep 2014
Hi OBC, just checked out your thread on propellerpowered. This is very exciting. I can see this opening a lot of doors toward some IoT stuff using uMite.
GREAT WORK!!!! Thanks!
Posted: 01:08pm 23 Sep 2014
I have some of the modules on the slow boat from China so you have saved me a lot of reading.
I have been dismayed at the power requirements of any Ethernet or wireless module I have used.
It makes low power devices difficult to make.
At the moment I an using Raspberry Pi's for my serial to Ethernet devices and that way most of the static web pages can be easily catered for with the Pi, leaving the uMite for the useful bits.
Posted: 01:14pm 23 Sep 2014
The RPi has scary power needs!
     Page 1 of 7
